Air filter,1982 XJ 1100 Maxim Thanks in advance!
Looking for Stock Air Filter
Marcus Turner
Portland, Oregon
1982 XJ1100 Maxim
http://profile.to/marcus_turner
http://twitter.com/marcus_turner -
air filter
HI, go to the local Yamaha dealer, or you can find them online at Bikebandit.com. Any good mc repair shop should be able to order one for you if there is no dealer around. Good luck, they are not cheap, like 40.00 but they last forever. K and N makes one that you can reuse but they tend to make bikes run lean and lean is not good for the xs1100 engines. Good luck, Mike in SD.mike
1982 xj1100 maxim
1981 venture bagger
1999 Kawi Nomad 1500 greenie
1959 wife -
Thanks Mike, Much Appreciated!Marcus Turner
Portland, Oregon
1982 XJ1100 Maxim
http://twitter.com/marcus_turnerComment
air filter
Hey Marcus,
Just checked Bike Bandit and they want $53.xx for the OEM filter and don't even show a K&N for it. I'm in the same boat as you with this, although mine is still very clean. Someone wrote a thread where he used foam filter material, and someone else used K&N filter material.
Good luck.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
Air Filter
I found one on this site http://www.babbittsonline.com/pages/.../2/Yamaha.aspx
Also on this site Thanks to soccer4m
Bikebandit.com
They're spendy, but I really want to keep my bike stock. I am having the Carb rebuilt as we speak. I have owned my bike for almost five years now and never had a lick of trouble until I ran the gas down and sucked some rust in to the Carburator. It's still a very sweet bike!Marcus Turner
Portland, Oregon
1982 XJ1100 Maxim
need a gas filter
Hey Marcust, if you sucked some rust you need a gas filter on each of your gas lines asap. Hopefully you have the two needed, if not, they will stop the rust-dirt problems. They are cheap, and easy to cut the line and pop in. There are lots of threads on how to do it, I find just get the smallest clear gas filters from any cycle shop and pop in. THe filter in the tank is almost worthless or aged and holey. Keep the bike stock and it will run forever. My bro inlaw tried the Kand N filter and it messed with his carbs running, so keep it stock. You can wash out the original filter, by using a gentle soap and brush. It saves some bucks and these filters really never get that dirty because of their location on the bike. So, gas filters, clean your air filter and ride on. Maybe you can make the XS Rally in central Ca in june? SHould be lots of XSives from the area. Mike in S.Diegomike
1982 xj1100 maxim
1981 venture bagger
1959 wifeComment
Thanks again Mike. It's in the plan to put some filters on on the bike.
The bike only had 5k miles on when I got it in 2003. It now has 19k.
I had a XJ 750 in college so that is what I was looking for originally. I was lucky enough to find the XJ110. It had been sitting in this guys garage for almost 20 years. I had the Tank repainted without the "YAMAHA" emblems and added some chrome here and there but other then that the bike is stock. Thanks all for the suggestions!!!!
Marcus Turner
Portland, Oregon
1982 XJ1100 Maxim
I bought a stock air filter from this site. Look under "Intake"
34.15 plus shipping. Took about 4 days to get it U.S.P.S.Rob
82 XJ1100
Stock..With a few cosmetic changes.
Current Project..Dad's 81 1100 Special
http://s727.photobucket.com/albums/ww272/RiderXJ/Comment
Rob that's fantastic! That's the cheapest I have seen it anywhere! Thanks!!
MarcusMarcus Turner
Portland, Oregon
1982 XJ1100 Maxim
