Well I've finally gotten ready to reassemble my XS 1100 motor with a 1197 bore kit for the second time. I did this for the first time last year, but somehow managed to bend the lower oil ring rail on the number one cylinder during assembly. This unfortunately scored the cylinder sleeve when the engine was run. So, the scored cylinder has now been changed out. Any tips on getting the rings installed? Last time, I used the "compress the rings by finger" method and wiggling the cylinder block on, piston by piston.I thought I was being gentle enough, but obviously was not. The Wiseco rings are much bigger than the stock ones, so they extend past the bevel on the bottom of the cylinder. I've heard of people using hose clamps etc, to compress the rings. Any ideas on how to ease the assembly would be welcome, as I definitely do not want to have to go through this process again.
thanks
Leo
					thanks
Leo
	 (Sold back to Maximan)
	 to see me?"
 to see me?"
 One of many wise ones on this forum.
	 But if you have a good condition low mileage engine, the it's probably not worth the $$.
