Shiftforks
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    Shiftforks
    I am assembling the engine on my 80xs special. I have manipulated, coaxed, and asked politely, but in the end, it seems that the second shiftfork teeth either do not want to or are not supposed to fit around the cylinder as the other two do. I wish I had taken better photos of the dismantle, but because I didn't, I need to ask for help. Can someone send me a photo or explain how the forks are supposed to sit? The images in my manual are not really clear.
    I'd really appreciate it.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
    • 8892
    Make sure the shift drum is in the 4th gear position. Shift fork #2 goes to the main shaft of gears, and it can only fit one way. It's a bit tricky, fitting these forks in, but you'll get it.
      Here are a number of pics of mine as I dismantled toward the gear removal.
      Like Phil said, the middle fork works the gears on the main shaft, thus you can not see where it goes in those pics. But once you get it turned the right way and start it up there it should be obvious and slide on pretty easy.
      HTH
      • FJ111200
        • Oct 2007
        • 317
        • Crewe, Cheshire, UK
        When i did mine i was having that problem, so i slightly turned the middle gear assembly by hand, and then all the gearing fell into place on the drum. All the best.
