No power
  • cowboy5
    • 60
    • toronto, ontario
    No power
    hello, this may be a stupid question but someone has told me something i need to clarify. i took my bike for a ride to the local salvage shop on saturday. rode like a dream. got some parts for my xj1100 maxim at a good price. anyways i came back out of the shop and went to start it and there was nothing. no lights, power anything. i checked the fuses and seem to be good. someone told me there may be an oil level indicator that will not supply the bike with any power if it is low. is this true as i have never heard of this. the lights dont even power on. well i left it at there shop on staurday and they said they may get to it by the end of this week. just want to know if anyone has any ideas
    Steve Josch
    Toronto ontario
    1982 xj1100 maxim owner
    • 8709
    I'd check the main fuse first. Another thing is the plug going to the ignition switch can overheat and melt. Happens on XS's, probably could on an XJ. HTH
      Sounds like either main fuse or ignition switch perhaps. Do not know the XJ that well, but I have not heard of any cage or bike that has a proof of oil to allow power to turn on to anything or even to start. The most I have ever seen even on brand new stuff is either oil pressure gage or light to let you know if your screwed.
      If it were me, I think I would get it the heck away from that dude. Being the fairly suspicious type that I am, I kind of wonder if they did not go out and dork with it while you were gettin parts to begin with. Seems kind of fishy to me anyway. But I am like the Wilfred Brimley character in the movie "The Firm" ..."I get paid to be nervous when there is nothing to be nervous about".
      • HobbyMan
        MeatHead Idiot "GURU"
        • 1801
        • Colleyville, TX
        Havn't had an XJ but..
        The fuses "seem good"? Did you check with an ohm meter or just look at them? Are they the glass type? If they are, they can burn at the caps where you can't see them, so they might "look" ok.
        Did you check the battery? Just put a volt meter on it to see if it is completely dead.
        Acta Non Verba
        • cowboy5
          • 60
          • toronto, ontario
          yeah, i just looked at it. did check the battery though was around 12.48 volts
          i have one glass fuse and the rest are the ones that are plastic with the two prongs sticking out
          Steve Josch
          Toronto ontario
          • HobbyMan
            • 1801
            • Colleyville, TX
            I am placing my bets on the glass fuse. Throw a new one in and see if it works. Can't hurt.
            Acta Non Verba
            • Cobia
              • Jul 2007
              • 1587
              • Palm Beach County, Fl
              Main Fuse is under the seat...
              Hey Cowboy,
              Had that happen to me a couple of times on my XJ and it was the main fuse that's either in front or to the rear of the battery. It's an in-line fuse on a wire that crosses from one side of the bike to the other. BTW - It looks like a connector because instead of being round, like a regular in-line fuse holder, it has a compartment for a spare built in. My fuse looked good and I got away with wiggling it a couple of times, but eventually when I pulled it due to lack of cooperation it came apart in my hands. One of the caps had separated from the assembly.
              Good luck.
              1980G Standard, Restored
              Kerker 4 - 1
              850 Rear End Mod
              Automatic CCT
              1980GH Special, Restored
              '82 XJ1100 (Sold)
              • BigDick
                • 521
                • McConnell AFB, KS
                Originally posted by Cobia
                My fuse looked good and I got away with wiggling it a couple of times, but eventually when I pulled it. . .it came apart in my hands. One of the caps had separated from the assembly.
                I had that exact thing happen. I'd start here.
                1980 XS11SG
                Dunlop elite 3's, progressive fork springs, tkat brace
                Stock motor, airbox, carbs, exhaust
                ratted out, mean, and nasty
                • slow mo
                  • 858
                  • ontario canada
                  new fuse block
                  hi i just got rid of my glass fuses and installed a new fuse block! they are available for purchase on this site! hope this helps you with your problem,, ride safe ,,slow mo!
                  The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
                  moemcnally@hotmail.com
                  i AM THE KING OF NOTHING
                  the people here are great , doesn't matter about the bike really/hamjam ////
                  • soccer4m
                    • 694
                    Kill switch?
                    Hey Cowboy,,,did you check the engine rocker kill switch on the right handlebar? That would cause all the issues, its happened to me when I inadvertantely push the knob when getting off. Anyway, hope thats it and not an electrical complication,,,so check it out. Good Luck, Mike in S.Diego
                    mike
                    1982 xj1100 maxim
                    1981 venture bagger
                    1999 Kawi Nomad 1500 greenie
                    1959 wife
                    • tarzan
                      • 1700
                      • Chandler,Az.
                      Could just be a bad connection.Id check battery connections and maybe check
                      for a bad ground.
                      80 SG XS1100
                      14 Victory Cross Country
