Idel mixture screw
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    Idel mixture screw
    Has any one ever had to drill out the broken idel miixture screw, hope this is gona work.
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
  • dbeardslee
    • 4385
    • Maineville, OH
    Are you saying you broke a tip off?
    • cowboybob998
      • Mar 2009
      • 371
      • KC MO
      These carbs I bought had three of them broke off, the salvage yard I bought them from said they came off a runing bike, they lie and wont make it good, any way i drilled them out, they would not come out, had there diferent people try to get them out, I driled em out with a twist drill,I think it may work just gona be hard to get them set, got any sujestions ?
      1979 xs1100 f
      floats @ 25.7
      1979 xs1100 F
      • tarzan
        • 1700
        • Chandler,Az.
        OK Cowboy step back from the drillpress and relax.lol.
        You can drill a stuck screw out,but it is easiest to use a mill so you can control the drill or endmill.
        If your talking about a screw tip stuck in the tiny hole in the venturi,then you can try and push it back through from inside the venturi with a right angled icepick.
        Either way there are pics and instructions on this in the tech tips.You just need to search abit
        Rick
        80 SG XS1100
        14 Victory Cross Country
        • cowboybob998
          • Mar 2009
          • 371
          • KC MO
          Rick
          I tried all the methods in the tec tips, did not work, was afarid of damaging the carbs from thying to poke them out so I just driled them out allready, at this point I figured I had nothing to louse, dont have acess to a mill so did the next best thing, took a tiny drill bit and drilled them out and then drilled the hole out just a little biger,1/16 bit, gess I wont know if it is gona work untill I get them on and see how they adjust out, gess I was hopeing some one elece had done this before with good results
          thanks
          1979 xs1100 f
          floats @ 25.7
          1979 xs1100 F
            Originally posted by cowboybob998
            - - - I just drilled them out allready, at this point I figured I had nothing to loose, don't have access to a mill so did the next best thing, took a tiny drill bit and drilled them out and then drilled the hole out just a little biger,1/16 bit, - - -
            Hi Bob,
            my son did the exact same fix on the centre carb of his XS750. (exact same carbs, just about.) and it worked OK.
            We drilled the busted needle tip out with a 1/16" drill bit because that's the smallest one our drill press chuck can hold. The hole is supposed to be 0.039" (1mm) diameter and 0.0625" diameter is mebbe twice the area so the needle needs to be not as far out as before. We found that half the number of turns as formerly worked OK.
            • cowboybob998
              • Mar 2009
              • 371
              • KC MO
              Hi Bob,
              Good deal, hoped someone elece had done this with good luck, thanks, now i can relax, lol.
              1979 xs1100 f
              floats @ 25.7
              1979 xs1100 F
              • corey
                • Mar 2005
                • 208
                • Dexter, MO
                I had to do this too, a while back. Easy with the drill and you'll get it. I buggered some threads and had to tap the opening. If you need the tap size i can get it for ya... the tap is out in the garage.
                Corey J. Bennett
                '79 XS1100SF
                • red bandit
                  • 955
                  • central michigan
                  With a 1/16 hole I think the spring on the mixture screw will bottom out before the screw will bottom in the hole so you will have to shorten the spring to get to get the screw to seat in the hole.
                  79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
                  79 SF parts bike.
