After around 2 hrs on the road, the bike stops running. Have seen the sidestand warning on LCD screen only once, but cutout doesn't seem to be related to road condition, turning, straightline, etc. Restarts immediately, but once it starts cutting out, it continues to cut out repeatedly and with increasing frequency. I've checked on new replacement parts for the sidestand switch and sidestand relay, but Yamaha says they're discontinued. Any tests, repairs, modifications, or parts sources will be greatly appreciated. Thanks...
XJ1100J -- Engine Cuts Off during ride
The sidestand switch should only be suspect if the bike won't start. Given the problem you described, I suspect your problem is in other areas.
When there is a sidestand problem, it is generally in the switch mounted by the sidestand. You can bypass the switch. Remove the seat. Track the sidestand switch wiring to a 3-conductor connection just behind the tank. (On my XJ I did not have to remove the tank to find this connector.) Unplug the switch. The 3 conductors need to be tied together; I did this by taking some wire and crimp-on 1/4 inch spade connectors, maing a "Y" cable that has all 3 wires connected to each other, and slipped the connectors onto the bike-side terminals in the connector. This makes the system think the side stand is in the 'up' position at all times.
Try this and see if the problem persists.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy Strut -
Re: XJ1100J -- Engine Cuts Off during ride
Originally posted by ltay948
After around 2 hrs on the road, the bike stops running. Have seen the sidestand warning on LCD screen only once, but cutout doesn't seem to be related to road condition, turning, straightline, etc. Restarts immediately, but once it starts cutting out, it continues to cut out repeatedly and with increasing frequency. I've checked on new replacement parts for the sidestand switch and sidestand relay, but Yamaha says they're discontinued. Any tests, repairs, modifications, or parts sources will be greatly appreciated. Thanks...Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
Check the tank vent....Comment
