Spanner wrench???
  • kirmit77
    • Mar 2009
    • 464
    • Kingwood, TX
    Spanner wrench???
    I need to find a spanner wrench to take off my triple trees. Sears has som but so many. What size do I need?!?!?!?!?
    Gotta go get it now!
    Thanks
    Austin Ingalls
    MIDNIGHT FURY
    1979 XS1100 Special [Full Restore Project]
    XJ maxim rear air shocks
    KERKER 4-into-1 exhaust
    Pod Filters
    Money pit.......
    BLACKED OUT
  • dbeardslee
    • 4385
    • Maineville, OH
    If you're talking about the big chrome nut in the middle, 22mm should get that off. Underneath you will find two gear-like locking nuts. You can use a channel lock to get them off, or mikesxs sells a ring wrench that fits 'em perfect - Mikes XS Part #35-3005
    • GARTHXS
      • 1631
      • Seattle
      good luck!
      Trying to get that sucker off with a spanner , I used a chisel and hammer to spin the top lock nut off
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
      • kirmit77
        • Mar 2009
        • 464
        • Kingwood, TX
        already tried.....
        channel locks. I have everyone you can think of. Harbor Frieght has a set ill get today and ill try them all. Its those stupid lock nuts. PITA!!!!
        Austin Ingalls
        MIDNIGHT FURY
        Pod Filters
        Money pit.......
        BLACKED OUT
        • dbeardslee
          • 4385
          • Maineville, OH
          Kermit - A flat-bladed screwdriver and a hammer will do it - like what garth was saying. They shouldn't be on there too tight. I think the torque spec is only about 7ftlbs. Just put the tip in one of the slots on the side closest to the front and tap it a little - top nut first.
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            I thought spanner was Brit speak for wrench... Anyway I use a socket and a breaker bar if it's stuck but most of the time a ratchet is enough. I've never chewed one up to where it had to be replaced.
            Geezer
              A Spanner is.. what in the US is called an Open End Wrench
              A Wrench is... what the Brits call a Ring Spanner
              At least so I have been told
                These things, right?
                McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                McMaster calls them spanner wrenches but back 'ome we called them peg wrenches.
                BTW you need two of them to keep the steering head bearing adjustment from shifting as you lock the peg nuts together.
                Some common North American tool names followed by the English equivalent:-
                wrench = spanner
                Box-end wrench = ring spanner
                Vise-grip = Mole wrench
                Crescent wrench = adjustable spanner.
                Pipe wrench = Stilson
                And to add to the richness of the English language, in Scotland Spanner = Key
