cHOKE Only
  • PacerXS
    • 6
    • Kansas City,Mo
    cHOKE Only
    Started 80SG after 2 months away. Installed new battery. Will not run unless full choke. Will not tolerate any throttle. Any ideas?
  • PacerXS
    • 6
    • Kansas City,Mo
    Thanks
    This was my first post and I failed to search the threads to see if the question had been asked already. I'll start on the carbs after a dose of Seafoam.
      Hi Pacer & welcome,
      runs on all 4, right? Do a search here on "carb cleaning" Believe the "triple clean" advice. The hard part is getting the carbs clear of the accurséd air box.
      My own prejudices prompt me to say that after you have bloodied your knuckles from working on said airbox you may also want to do a search on "pod air filters"
      • PacerXS
        • 6
        • Kansas City,Mo
        Pod Filters
        I have read that jetting a bike with aftermarket filters can be a problem,especially for a neophyte.
        • dbeardslee
          • Nov 2007
          • 4385
          • Maineville, OH
          Pods will usually lean it out a little, so you may have to go a little bigger on the mains. There's a post in Tech Tips under Modifications labeled Jetting Recommendations that will pretty much tell you what size jets you will need. While that may be a minor pain, nothing like the pain you'll feel after the 10th time taking the carbs off with the stock airbox in place. Pods makes it a LOT easier to pull the carbs, which I think is what Fred was driving at.
            • 2088
            I 2'nd that seafoam should be put in the tank and let it run for a bit then let it sit overnight.Also you might want to spritz the pipes to see if they sizzle.If they do at least they are getting fuel.Do not run the bike with it continually on choke.
              • 7832
              If the bike will only run with the "choke", the pilot jet is plugged! Seafoam, and I say a full can in about 1 to 2 gallons of gas, may do the trick. Just do as oldyam80sg said, and try again in the morning.
              • Ivan
                • Jul 2008
                • 2524
                • Hutchinson KS
                Yes, the "choke" on these bikes bypasses the pilot circuit with an extra rich slosh of fuel air mix. But two months probably didn't plug your idle jets. If it did, you need to buy different gasoline, cause that stuff is nasty.
                Did you let the bike warm up at all and see if it would run without the choke? Mine is really touchy on cold start up, and don't like running much until warmed up. Definately won't take any throttle when cold and no choke, if it will idle at all.
                Ich habe dich nicht gefragt.
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  I had a similar problem on mine. It turned out that the little jets in the actual float bowls were part of the issue. I would say to be sure that all the jets and tiny passages in the carbs are clean, and that will most likely solve your problem.
