'84 XJ1100...narrowing down the problem
  • jamatta
    • Mar 2009
    • 16
    Originally posted by Crazcnuk
    I would ask why you think the pilot jet is plugged?
    The pilot jet sits, upside down, above the float bowl. The only way it can get plugged, really is if it sucks up a large chunk of floating debris?
    You can remove the float bowl, with the carb in the bike. You just need a shorty phillips screwdriver.
    I think I might be able to remove the float bowl. It might be tight, but then I don't have to deal with the choke, throtle, air box and whatever else might be attached to this one carb.
    I think it is the pilot jet because I have checked to make sure there is spark. All other pipes get hot except # 1 and I have no problems once the bike gets going and the main jet kicks in. (mind you I didn't know what a carb was last week, so this is just what I think it is from reading on this site, and from all the help)
    I might try to fiddle with the float bowl and try to get the pilot jet off, leaving everything still attached. That way if I get over my head, I just have to screw the float bowl cover back on (again a real newbee)
    thanks everyone again for the advice....stop me if you think what I'm about to try is wrong or won't work. I won't be doing it until my days off next week so will check back here to see all you advice
    '84 XJ1100 Maxim
      Have you checked the mixture screw setting? IIRC, and some of the gurus can and probably will correct me here, the mixture screw does effect all the way up to the mains kicking in. You can try turning it down to very lightly seated position and counting the turns. then put it back. Try the same with one of the others, and put it back. Will tell you if it is close anyway.
      I would think that the fuel that flows through the pilot jet will still be in there when the bike is shut off and may dry up. Also, sitting on the side stand, fuel level will be pushed up in the bowl to one side and may get up to the pilot jet. I just set my valve clearnaces yesterday (first time I have done that..ever) I was very surprised at how much oil was in the valve pockets for no 1 cylinder form it sitting on the side stand. All the others had very little oil, but the entire lifter was covered in no 1 cylinder valves. JAT. HTH
      • wingnut
        • Oct 2005
        • 695
        • NC
        This may help
        wingnut
        81 SH (Daily Ride)
        81 XS 400
        Thomas Jefferson
        • Crazcnuk
          • Aug 2006
          • 2980
          • Hinton, AB, Canada
          I have the air box, thx, and it's a 5 minute job to get them out.
          There are only 3 screws to the airbox, 2 for the seat and 1 for the gas tank.
          If you try and shortcut any of these, yes it'll take 30 minutes.
          '05 ST1300
            Crazcnuk,
            He has an XJ, NOT AN XS!! The airbox is totally different, as is the air filter!! As Tod said, it's a 30 minute job, WHEN YOU KNOW WHAT YOU ARE DOING!!
            Jamatta,
            TRY and find some seafoam. Go to a BOAT SUPPLY SHOP and see if they carry it! Put the FULL 1 PINT CAN into the fuel tank, run it for about 5 miles, and then let it set overnight. Fire it up the next day, and ride it, including some wide open throttle runs in third gear. That should clean the carbs, and if not, THEN start to go into them.
            • Crazcnuk
              • Aug 2006
              • 2980
              Ah, ok.
              "I think it is the pilot jet because I have checked to make sure there is spark. All other pipes get hot except # 1 and I have no problems once the bike gets going and the main jet kicks in."
              Ok, this should preclude the pilot circuitry! The pilots are not doing anything at idle. I think you are dealing with the idle circuits, as DGSXER was saying.
              You are not fully on the mains until way up in the rpm range. Is that cylinder kicking in at 3000rpm or 6000rpm? It could still be a pilot issue, just trying to narrow things down abit!
              The pilot and main jets are right in the center of the carb, almost above the fuel level when the carbs are full. Any evaporation, and there should be very little fuel in either of these circuits, maybe 1/4' at the jets themselves. Even on the side stand. I am pretty sure this was by design to keep residue and varnish to a minimum.
              '05 ST1300
