Carb help please 1980 XS-1100 Spcl
  • greengoon3
    • Sep 2008
    • 50
    • Chesapeake Virginia
    Help?
    I am confused.
    While looking through a parts list and parts breakdown for the carbs for my XS-1100 spcl, I noted different part numbers for the bowls.
    On my XJ650 it matters due to the location of the bowl drain screws.
    Am I missing something here ? ?
    Stupid me? I marked the carb bodys but thought all the bowls were the same.
    Also the 1/8" balls and springs for the enrichment operating rod detents is gone. Dont know if I lost them or they were never there.
    I found the balls on a web site that also offers the fuel Tees for the rack(found the info fir that on this site of course!).
    No info on the springs...
    1 found a small spring in the garage floor, but no balls not sure if this is one of them or not?
    Anyone have any suggestions?
    Thanks for any and all help!
    George
    1980 XS1100 special
    4 to 1 Kerker exhaust
    120 mph speedo.
    1979 carbs jetted 147 mains
    47 idle
    1980 XJ 650
  • randy
    • Dec 2003
    • 4521
    It matters for the same reason on your 11. You have left and right bowls. Take a close look at them.
    That little ball is just a 1/8" ball bearing, you may be able to find it a a hardware store, or Bikebandit. Yes, that little spring is probably for the choke rod??? Is it about 1/8" diameter??
      • 7765
      Lets start at the Bottom!
      Just put the bowls up to the bodies, and see what direction the drain screw faces. Should be an easy "fix", as you want the "drain" pointing to the outside of the engine. You probably have two left and two right. If they ARE all four the same, no worries!
      Next question:
      I would keep the spring you found, and get one 1/8" ball as a replacement. Put the one set in Carb #1. I use a rount tooth pic to keep it in place while starting the rod. Don't forget to LUBE the spring and ball!! I use a synthetic grease so it is water resistant. You should coat the rod with a THIN film, so everything slides properly.
      • greengoon3
        • Sep 2008
        • 50
        bowl id
        All the bowls have the drain screw in the middle. Actually drain plugs. Everything else looks the same. rto the untrained eye...
        1980 XS1100 special
        120 mph speedo.
        47 idle
        1980 XJ 650
          • 8794
          You have the early type carbs. All the bowls are the same. Put the nicer lookin' ones on the outside carbs. Also, make sure that small hole in the bottom of the bowl is clear. That is how the fuel enricher (choke) gets it's fuel.
          • Crazcnuk
            • Aug 2006
            • 2980
            • Hinton, AB, Canada
            Some 80 and 81's came with the drain plug in the middle too.
            I have one set of each, both 80's.
            '05 ST1300
            • Snareguy
              • May 2021
              • 33
              Guys. Where do i put the ball im lost. 1979 xs special
                • 1909
                The balls and springs go in the number 1 and number 4 carbs so that the choke lever detents catch on them. On most unmolested carbs there is no place for them on 2 and 3, although many drill a spot for them when swapping carb bodies around.
                • Snareguy
                  • May 2021
                  • 33
                  I think this is why my choke idle is almost at 2-3k range. Thanks do i need to open up the carb or is the entry hole on the outside of the carb? sample pictures if possible? or a number on the diagram? cajun31
                    • 8794
                    The spring and ball go in the small hole to the right of the idle mixture screw in the picture below.
                    The choke rod must be removed first obviously. Click image for larger version  Name:	IMG_20220416_180007.jpg Views:	0 Size:	149.0 KB ID:	868376
                    • Snareguy
                      • May 2021
                      • 33
                      bikerphil to the rescue! Thank you brother! Did you vapor blast those carbs? Looks very clean.
                        • 8794
                        Yep, I think they were, I bought them like that. Unfortunately the guy who rebuilt them f'd them all up. They look nice but that's about it.
