Replacement air filter
  • BossMaverick
    • Aug 2008
    • 130
    • Montana
    What brand of air filter for the stock air box are you guys running?
    I have tried the one from partsnmore and an emgo air filter I bought off ebay. Both are too tall for my air box and causes a gap in the seal no matter how hard I tighten the screws. I don't see how it could be a problem with my air box but has anyone else problems with the partnsmore and emgo filters?
    I'm assuming that if I switch to a K&N or Uni I will have to change my jets which I really don't want to do at this point. Am I stuck buying an expensive Yamaha brand filter?
    Thanks!
    1980 XS1100 Standard "Touring"
    Fairing, Trunk, and Bags
    850 FD
    Fork Brace
    Progressive Front Springs
    Engine Guards w/Foot Pegs
    Oil Cooler
    Throttle Lock
    Uni Air Filter in Airbox
    2009 Suzuki Bandit 1250S ABS
  • dbeardslee
    • 4385
    • Maineville, OH
    Boss - I was running a foam replacement filter from JCWhitney that worked fine. It was oilable, washable and fit well. Here's a link - http://www.jcwhitney.com/REUSABLE-FO...4687_10111.jcw It did not look like the one in the picture. It was yellow foam, and the foam is completely removeable from the frame. Shouldn't cause problems with your jetting.
    • SFerinTEXAS
      • Jun 2006
      • 877
      I got a partsnmore filter and had the same problem. Scraped off the foam on the outside edge and it fit good. Still using it.
      79SF
      XJ11
      78E
      • rockjok
        • 151
        • Montana
        I've been using KN air filters for quite a few years tho' I've got a couple of JCWhitney filters in a box somewhere. The KN's are great but you NEVER want to use HOT water when cleaning them since they'll shrink just enough not to fit. After I discovered this I haven't had a problem with them.
        Now if I could figure out how to keep the mice from nesting in my air boxes I'd be happy. Last year I jammed some steel wool in the intake which kept them out but of course I forgot about it when I tried to start 'em in the spring. Guess I need some "Remove Before Flight" ribbons.
        Rob
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          I'm also using a K&N in the stock air box. No problems.
          Tim Ripley - Gaithersburg, MD
          23mm float height
          120 main jets
          42.5 pilot jets
          drilled stock airbox with K&N
          Jardine 4 to 1 Exhaust
          spade fusebox
          1st and 2nd gear fix
            • 2062
            Modified K & N that XSChop made
            • dbeardslee
              • 4385
              • Maineville, OH
              Oldyam - That's a cool lookin' setup. Do my eyes deceive me, or are those pingel taps? Looks like you went with the good stuff .
              • yadada
                • 150
                • Louisburg, KS
                Rob
                Off topic, sorry...My uncle uses mothballs on the grain truck motors on his farm to keep mice from making a home under the hood. Don't blame me though when you start it, and think you're losing your marbles.
                Randy
                "I didn't break it! IT FAILED!"
                '82 XJ1100 "yamama"
                '09 Buell Ulysses
                '01 HD softail std - crunched
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  How's he get their tiny legs apart?
                    • 2062
                    Dbeardslee-Yes,those are Pingel petcocks that are on there.I got them back around 1991.I recently had them rebuilt for around $20.00-new screens and new o-rings.They work and look great.Well worth the money.
                    • BigRickxs1100
                      • Mar 2009
                      • 19
                      • Bloomington/Normal IL
                      Hey oldyam80sg I love that set up. Is there any how to directions on how to build that same setup or did XS chop do this custom??
                      1978 XS 1100 Standard - Bobber project
                      www.fullthrottlefurniture.com
                      • BigRickxs1100
                        • Mar 2009
                        • 19
                          • 2062
                          XSChop did the filter set-up.
