Help Gas in my oil
  • gmlever
    • Mar 2007
    • 22
    • Iowa
    Help Gas in my oil
    Hi Guy's
    I've done some reading on this and I want to make sure my thinking is correct ? First I pulled both lines off my petcocks in the off position,wanted to make sure they worked when shut off. Only did that on the left side,then on the right side I pulled the line off the tee going to the carb with the petcock in the off position it was fine until I turned the gas to the on position then gas came out of the tee ? Does this mean my Octy isn't working ? That's what I'm thinking.Btw drained oil 1/2 oil 1/2 gas.
    It's a 1980sg all original 11,000 miles.
    Thanks for any help !
    Gmlever
    80 XS1100SG
    Tkat fork brace,Progressive suspension,
    E3 tires,Iridium plugs,Mikes black coils,Standard handlebars,Kerker header.
    Ankeny,Iowa
    Your two faced....and you have a drinking problem.
    Well..your problem is two faced anyway.
    From what you described, your Octy (since you have a special) is not working. Fairly common problem and you can get a rebuild kit for it. Or, like many who have gone before you, you can chuck it and simply pipe your ON position petcock outlet to your carbs. Your options on the prime outlet are to T it in as it is now, cap it off, or run a fuel line between the two (such that they would essentially feed each other).
    The other side of your difficulty is the float valves in your carburators. The Octy is not the control for gas flow into your carbs, it just controls if flow can get to your carbs based on whether or not your engine is running. When the engine is running, it constantly allows fuel to flow to the carbs. There is a float with a valve in the fuel bowl that stops the fuel from flowing into the carb when the bowl hits the "enough" line. Your carbs don't know when to say when!
    Since you have fuel in your oil, and most likely a nice puddle in your air box if it is still stock, they are not cutting off the fuel flow when the bowls are full. You need to pull the carbs, and clean and or replace the needle valve and seats, and check your floats especially if they are the older brass ones. I think the 80 models had the newer plastic ones though.
    • gmlever
      • Mar 2007
      • 22
      • Iowa
      Thanks for the info
      This might give me a drinking problem before its over ?
      I was fairly sure the Octy was bad, a rebuild kit would be great I haven't seen one all I found was a new one on Bikebandit $93.02 kinda pricey !
      I cleaned the carbs last year and everything worked great I thought ? I guess I should have put new needle and seats in then ? Not much gas in the air box probably because it's on the center stand ?
      Any other suggestions ??? Octy rebuild kit where ?
      Thanks again !!!
      80 XS1100SG
      Ankeny,Iowa
        Not sure where to get the rebuild kit, others have mentioned it. Mine is sitting on my tool bench. I piped it out of the picture. Maybe one day I will reseal it and try it again.
        • tarzan
          • 1700
          • Chandler,Az.
          George fix on EBAY has the rebuild kit for the octy.Also check partsnmore,I think they might carry them.
          I took my octy off and really never shut the fuel off and mine doesnt leak.
          So like was already alluded to,your needle and seat are leaking.Or under the seat(float valve seat) is an o-ring,pull the seat and inspect those , they are a common problem.
          Welcome to the club.
          Rick
          80 SG XS1100
          14 Victory Cross Country
          • gmlever
            • Mar 2007
            • 22
            • Iowa
            Thanks again for the info I guess I better start looking for Carb kits.
            BTW a little info for everyone I just got new progressive fork springs and 412 progressive rear shocks from underbid.com saved about $50.00 and only took about 6 days Good deal.Thanks to a nice tax return...
            80 XS1100SG
            Ankeny,Iowa
              • 1966
              thought I would throw my two cents in on this conversation. Check out this link on Ebay http://cgi.ebay.com/ebaymotors/Fuel-...em370174721406 or this one http://cgi.ebay.com/ebaymotors/YAMAH...em200321443606. These are listed as petcock rebuild kits. If you look at the picture the square piece of rubber with the small piece of metal in the middle is for your OCTY. It is all you need to rebuild the OCTY and make it as good as new. The other parts are for the petcocks. This is what I used when I did mine and I have not had a problem with my petcocks or the OCTY. Another tip, when you are rebuilding the petcocks, don't get over zealous about it by put a little more bow in the metal ring that you will find in there. It will provide a little more spring that way after reassembly and the petcocks will seal better in the off position.
                Hi Gregg,
                as has been said, there are two problems, your octy don't shut the gas off and one or more of your carb float needles isn't seating.
                For sure the carb needles have to be fixed. In theory once the carbs are OK you don't need a working octy. Yeah, right.
                I'm with those who think the only good thing about an octy is the pretty splash you see when the octy hits the river. Others like them and yes they can be fixed. And all nine hoses replaced.
                My XS11SG came to me with it's octy already missing. First I put blanking stubs on the prime fuel stubs and tried to remember to turn the taps to OFF when I stopped just like the old days. Then I swapped in a Standard gas tank and those tanks have vacuum taps.
                • gmlever
                  • Mar 2007
                  • 22
                  • Iowa
                  Thanks Again !
                  Hey guy's Thanks for the good info I need all the help I can get ! I will be ordering parts from ebay and where ever else I can find.
                  Is there a good test to see wich needle's are leaking ? I will be replacing all of them just curious for now ?
                  I'm 50+ now maybe I'm to old to be playing with these kinds of toys ? XS11.com is a great place !!
                  Gregg
                  80 XS1100SG
                  Ankeny,Iowa
                    The only difference between men and boys is the size fo their toys. With age the toys just get to be more expensive.
                    As to which one is leaking, sure, take the bottom off of your air cleaner box, open your fuel taps to let fuel into the carbs. You will most liekly see fuel flow out of the air manifold to the leaking carb(s).
                    • cywelchjr
                      XS-XJ Super Guru(Deceased)
                      • 4450
                      • Sacramento, CA
                      Gregg
                      I don't think that 50+ is all that old for playing with these things, being there myself. I'm just getting started tinkering on mine, once I get my replacement engine in then I'll start on a full rebuilt with a bigbore kit, figuring on a couple of years to get that done. Who knows, by then maybe I'll have a second xs11.
                      • gmlever
                        • Mar 2007
                        • 22
                        • Iowa
                        Well good luck with your rebuild. Maybe we need to start a new club XS1100 50+ Club ? What a bunch of old farts on motorcycles as my son says.
                        80 XS1100SG
                        Ankeny,Iowa
                        • slow mo
                          • 858
                          • ontario canada
                          old farts
                          sign me up 59 this jan. cheers to old farts need a t shirt!!! slow mo!!
                          The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
                          moemcnally@hotmail.com
                          i AM THE KING OF NOTHING
                          the people here are great , doesn't matter about the bike really/hamjam ////
                          • greatnw
                            • 177
                            55 here! Having way too much fun putting this bike back together.
                            Bothell, WA
                            1980 XS1100SG
                            • DenyP
                              • 599
                              • Staples, Minnesota 56479
                              Ya like I am going on 59. In most situations I know my age - The 1100 tho makes me feel 21 again so screw the age thing!!! Most guys at 21 today would think the work necessary to get an old 1100 up to speed is not worth it. I tell you what, in my case my machine makes me and the wife young again. Can't put a price on that!!!
                              Deny
