MikesXS coil upgrade
  • Silent
    • 343
    • San Jose, CA
    I'm in the process of upgrading the coils/wires/caps, and just wanted to verify my thinking. I picked up a set of the coils per the tech tips, the yellow 7mm wires that MilesXS sells, and a set of LB05EP caps. I've noticed that the new coils have a + and -, and the old coils don't. Studying the wiring diagram leads me to believe that the r/w wires are the ground (-) since they tie together, and the Orange and Grey wires are the hots (+) respectivly.
    Am I correct in my thinking, or is this the second comming of Chernobyl?
    Thanks
    Ray
    '07 FJR1300
    You have it backwards. Red/wht is pos (+) giving the coils juice, and the org/gry go to neg (-). Org/gry are the trigger wires.
    • Silent
      • 343
      • San Jose, CA
      Thank you Phil!
      Gotta love all the knowledge and wisdom on the forum I was about to make nasty things happen to my electrical system
      Ray
      '07 FJR1300
      • black 82xj1100
        • Mar 2009
        • 27
        • Georgia
        Did mine last night. Cant get over the improved throttle response
        Hey did your boxes have a sticker on the end that told the part number along with cb/650/750/900 and made in Taiwan ? Makes me wonder if these are standard replacements for honda ?
          Silent! I tried to smash that bug running around on the screen. We have a house plant that hatches those damn gnats...
          • Silent
            • 343
            • San Jose, CA
            Heh I try and smash that bug on occasion too
            I musta messed something up when I soldered the wires to the new coils. I've got weak spark on one bank, and no spark on the other. I did bypass the resistor under the tank.
            Ray
            '07 FJR1300
              Send me a quick PM if you need any help. I'm in a "do nothing" mode for today, and can ride over the hill if you need a little help.
              • Silent
                • 343
                • San Jose, CA
                After reinstalling the carb rack, pulling the new coils and tossing in the old ones with a new cap, she fired up on all 4! Apperenlty when I soldered the wires onto the new coils I got one of the terminals to hot and must have damaged the coil internaly. I do know I did have problems with one coil trying to get the solder cleared out of the hole. The battery was down a bit, so thats probably why the weak spaark on the first coil.
                Now to figure out the air/fuel mixture and get her running the way she should
                Ray
                '07 FJR1300
