Carb Cleaning HELP
  • kirmit77
    • Mar 2009
    • 464
    • Kingwood, TX
    Carb Cleaning HELP
    Hi everyone, im new to the xs11. I have a 79 special and it has been sitting up since 85. As you can guess, everything is pretty bad. Hard Lines, dirt and grime ALL over, and the CARBS wont move. I took them off and green crap came out. NO GOOD. Whats the best way to clean them up? Should i soak them in gasoline then rebuild? Thanks in advance!
    Austin Ingalls
    MIDNIGHT FURY
    XJ maxim rear air shocks
    KERKER 4-into-1 exhaust
    Pod Filters
    Money pit.......
    BLACKED OUT
    • 7818
    I would spray the carbs with cleaner, and then PB Blaster. You can look at the links on the top of the page to find the thread on neglected bikes. That will probably be your best bet for now.
    • Rasputin
      • 3193
      • Lacombe, Alberta, Canada
      Yeah like DiverRay says above. Remember not to soak or dip them in a carb cleaner as it can bugger up the seals on the butterflies. Do a little searching and reading, you will find loads of stuff on how to do it. You will also find pitfalls to avoid. Good luck
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        No question rebuild , rubber seals are probably dried up ready to leak. Save yourself time and head aches and buy yourself a rebuild kit along with some butterfly seals. Soak the jets ,needles and bare carb body in some strong carb cleaner for a few days .
        BDF Special
        • latexeses
          • Jun 2008
          • 1491
          • California
          kirmit77,
          If you can get your hands on a sonic cleaner, do so and strip the carbs down and run them through that for about ten minutes. I didn,t pull the butterflies because the stems seamed to be fairly tight. Put all the carb parts through the cleaner.
          I ran a combo of Simple Green and Dawn dishwashing soap in the cleaner I have when I put in the carbs....
          I thought I had my carbs clean with aerosol cleaners. Could not imagine how much crud came out of them. Ran out of every nook and cranny.
          Don't know yet if they are in working order but it sure made me feel beter about only having to do the cleaning once.
          Rodger
          Everything on hold...
