Okay, so I'm cheap... REALLY cheap... The hardware store wanted $5 a piece for the two end caps I needed to close off some PVC pipe I bought for the vacuum gauge trick. So I said screw it and figured I'd just glue something flat up against the ends of the tube to create a seal - after all it's just vacuum, so it shouldn't be hard to seal.
But I was just thinking, does it really matter whether the PVC tube is a rigid volume, or can I just use something flexible like ceran-wrap on the ends, as long as it's sealed up? I don't know much about this pressure stuff, but it seems like the rigidity of the container isn't all that important. Could you use a couple empty 2L bottles of soda, for example?
Just curious - won't be hard to find something stiff and flat, like I was planning before.
Beautiful weather here in MI today, and the weekend is looking great. I've got the fever!!
Cheers,
Marshall
Cheers,
Marshall
JMO
I built one from it to do my synching, only the aquarium valve I bought (the only one I could find for miles around) is such junk I tossed it and just go one cylinder at a time with the vacuum line.
