Carb diaphram removal
  • petejw
    • 2269
    • sydney australia
    Start by cutting the top ring with a very sharp knife,
    place a screwdriver in the cut and carefuly pry the top ring off. To replace, i sprayed the diahpram with some silicon spray and carefully put the upper ring back on, the lower ring has a recess and the bottom of the diaphram must sit in this recess to seal properly, carefully pull on the diaphram till you feel the diaphram seat in the lower ring recess.
    Because the diaphram is a pressed fit youll need to tap the upper ring lightly for a secure fit being careful not to damage the diaphram.
    all done. :-)
    Last edited by Ken Talbot; 03-13-2009, 06:36 PM. Reason: allow inages to display full size
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    Well done, Pete. We'll want to copy that over to one of the permanent tech tips lists.
    Ken Talbot
    • petejw
      • 2269
      • sydney australia
      just read my above post and noticed i didnt give credit
      where credit was due,
      i didnt come up with this idea,
      i copied it from Mathh from the uk site, thanx mathh.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • Toolmaker Tim
        • 671
        • South Bend, Indiana
        Pete, I'm not quite clear on the cutting of the top ring. Do you reuse the ring that you cut?
        1979XS1100SF
        K&N's and drilled airbox
        Jardine 4in1
        Dunlop Elite 3's
        JBM slide diaphragms
        142.5 main jets
        45 pilot jets
        T.C.'s fusebox & SOFA
        750/850 FD mod.
        XV 920 Needle Mod.
        Venture Cam Chain Tensioner
        • Toolmaker Tim
          • 671
          Reusing top ring
          Ok, I looked closer and I see what was done now. The cut doesn't affect the ability of the ring to lock the diaphragm in place,correct?
          1979XS1100SF
          Jardine 4in1
          Dunlop Elite 3's
          142.5 main jets
          45 pilot jets
          750/850 FD mod.
          XV 920 Needle Mod.
          • petejw
            • 2269
            • sydney australia
            hi tim,
            yep thats correct, u can reuse the top ring, i never glued
            the base or the ring imo it wasnt needed and the diaphram
            is secure.
            if u do cut the top ring and plan on using the diaphram below it,
            just be real careful as it isnt to hard to cut the diaphram with the knife,
            if ur replacing the diaphram then this wouldnt matter.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • Toolmaker Tim
              • 671
              Very cool Pete. Thank you for passing on the process!
              1979XS1100SF
              Jardine 4in1
              Dunlop Elite 3's
              142.5 main jets
              45 pilot jets
              750/850 FD mod.
              XV 920 Needle Mod.
              • petejw
                • 2269
                • sydney australia
                no worries Tim.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • Rasputin
                  • 3189
                  • Lacombe, Alberta, Canada
                  If you go here and scroll down the page this guy has a good looking process going as well.
                  2-79 XS1100 SF
                  2-78 XS1100 E Best bike Ever
                  • petejw
                    • 2269
                    • sydney australia
                    one other thing that i didnt make a note of at the time
                    is making sure the hole in the slide is pointing to the front of the carbs
                    when the "tab" for a better word of the diaphram is seated in its spot.
                    in the above pics i havent done that, but have since.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • Toolmaker Tim
                      • 671
                      Well now that I know how easy it is,maybe I should put my spares up for sale. Maybe I can help someone out there that needs a set. They are getting hard to find.
                      1979XS1100SF
                      Jardine 4in1
                      Dunlop Elite 3's
                      142.5 main jets
                      45 pilot jets
                      750/850 FD mod.
                      XV 920 Needle Mod.
                      • petejw
                        • 2269
                        • sydney australia
                        hi ras,
                        i saw that when i bought my diaphrams a while back,
                        i tried it that way using
                        the old diaphram to remove it, i didnt like it.
                        cutting the top ring was
                        a much better and safer way of doing it without the worry
                        of ruining the new diaphram.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • Rasputin
                          • 3189
                          I was just trying to show that there are a few different ways of doing it. Many have preferences of one way over another. I have never tried it yet but have some to be doing so I am looking around for my best option. I forget where I got the pic I posted in the other thread but it was from a supplier and it showed the way they recommended doing it. Just the pic and no instructions. So if you or anyone else has had experience, I am listening
                          2-79 XS1100 SF
                          • petejw
                            • 2269
                            • sydney australia
                            i wasnt havent a go at u ras for posting it,
                            just stating that i tried it that way and
                            it wasnt a very good method compared to cutting the
                            top ring.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                            • Rasputin
                              • 3189
                              No I realize you were not having a go at me. I am all ears here learning new stuff. I was pleased to see your posts and every thing I find out will make my life easier when I do mine.
                              2-79 XS1100 SF
