I've got a few questions that hopefully y'all can answer!
I picked up a project '80 XS1100 with a Wiseco 1179 kit. The carbs were off the bike, but appeared to be correct for the bike. However, when trying to put them on, the spacing between the outer and inner cylinders appears to be off. What I mean is that if I line up say 1 & 2, I've got to shove the carbs over around 1/2" to the left to get 3 & 4 installed. Not the easiest thing to do!
2nd issue is that I've only got one fuel inlet on the carbs, right between 2 & 3. Everywhere in my manual it shows the inlets between 1&2 and 3&4. The tank has two petcocks, and I have no clue how to route them, other than teeing the two lines together and dropping them into the single inlet.
OK, do I have the wrong carbs for this bike, or am I missing something? The bike does run, and visually the carbs appear to be the correct type (i.e. from a Yamaha, CV type).
Help...
Sean
Help...
Sean
