Leftside oil seal
  • justme1100
    • Jul 2008
    • 243
    • Eagle, WI
    Leftside oil seal
    Does anyone have a picture of the pick-up/gov. oil seal? I just want to make sure I have the right one BEFORE I pull the old one. I used the info from this site to order one and I recieved a Federal/ Mogul with the part no. 223240. Wish me luck.
    Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
    • 7819
    If you searched the threads, and found the one about the seals, you are probably good to go. Just remember, the original seal has an INSIDE LIP that locks on the cases, so it will be a bear to pull!! Just do so carefully, and use a little semi-hardening sealer for the outer rim of the replacement seal.
    • thewiz
      • Oct 2006
      • 1115
      • Wilksboro, NC
      I've got a new one around I could photograph ...
      if you really need or want. Size should be 32x48x8mm with no bead on the outside edge. Don't think you can squeeze the factory style seal in there with out a case split. I used a Viton one but a Nitrile one would work as well. Viton has a higher heat tolerance.
      Like the Diver says, take care not to gouge the seal cavity when digging it out ... they tend to come out in little pieces. Couple hours of belly time unless ya' have a lift ...but not really a bad job or too hard at all. Fixin' it does wonders for the toe of your left boot too
      80G Mini-bagger
      Past XS11s
        • 7819
        Yeah, no longer a waterproof left boot, now they BOTH get wet!
        • justme1100
          • Jul 2008
          • 243
          • Eagle, WI
          I can always tell which is my left sock, oil stain on my left toe. Thanks Guys
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            That's funny, justme, ...
            So as not to descriminate against the 'right' boot, and just to even things up some, you could try leavin' the oil cap off and ride out a tank of gas .... right boot and sock will come close to matchin' the left ... don't ask me how I know.
            80G Mini-bagger
            Past XS11s
            • justme1100
              • Jul 2008
              • 243
              • Eagle, WI
              to even things up
              I would switch socks just so they all matched.
              • thewiz
                • Oct 2006
                • 1115
                • Wilksboro, NC
                oil seal pics
                Here's the seal, bro ...
                80G Mini-bagger
                Past XS11s
                • John
                  • 5117
                  Don't forget
                  To check for a slight groove in the end of the crank where the seal rides. If there is a groove, no new seal will stop the leak. Trust me. There is a sleeve available that can be installed over the end of the crank, in effect renewing the surface of the crank, preventing the leak. The P/N is National 99128. It will fit both ends of the crank.
                  • justme1100
                    • Jul 2008
                    • 243
                    • Eagle, WI
                    Thanx to all
                    I want to thank all who replyed. The project starts asap. Keep the fingers crossed.
