valves job, any tech tip / visual?
  • greg maz
    • Feb 2008
    • 219
    • Arlington Heights, CA
    vibrations at 3k, noisy warm up, nvr done them: time!
    how big the gap intake & out
    sorry for the routine topic, didn't find it in maintenance
    if the Chino mech is reading, how much?
    82 XJ1100 Klonk= SOLD
    No longer active member.
  • greg maz
    • Feb 2008
    • 219
    I remember reading about the same vibrations at 3k but couldn't find the thread again.
    Help?
    • corey
      • Mar 2005
      • 208
      • Dexter, MO
      Clymers?
      Its thoroughly detailed in there.
      I haven't done it myself (need to), but I've researched it on here. Found lots of info. Might try another search??? I believe I searched for "valve shims" or "valve shimming" or the like...
      Corey J. Bennett
      '79 XS1100SF
      • Crazcnuk
        • Aug 2006
        • 2980
        • Hinton, AB, Canada
        Not sure what you're asking here, but the 3-4k vibration was an issue with the vacuum advance. It isn't a problem and causes no problems, but people find it annoying.
        Yamaha sold a replacement vacuum advance unit, which I believe is no longer available.
        The top end SHOULD be a bit noisy when it's cold. The valve clearances are at the max when the motor is cold and takes a little warm up before they go away. If you get no valve noise when you start an XS, chances are your valves are too tight and need to be checked.
        To check the valves, take the valve cover off (20 bolts), and the timing cover (left side (4 bolts).
        Using a wrench that fits the wrench flats sticking out of the timing mechanism, turn the motor over (in the direction indicated by the arrow on the timing plate).
        This is easier if you have the spark plugs out, too.
        Watch the cam lobes, as you turn. Every time one of the lobes is pointing directly away from it's valve, use your feeler guages to check the clearance.
        At this point you will know if you need to change any. If you do come back and get the rest of the procedure.
        A manual is always handy. The clearance varies by year, I am not sure if the XJ is the same as mine or not, but I am sure someone will chime in.
        '05 ST1300
        • Steptoe
          • 175
          • Thabeban,Bundaberg QLD , Australia
          valve clearance
          i have clearances here,
          G[US]/SG MODELS, --inlet 0.11--0.15mm[0.004--0.006in]
          all others ---0.16--0.20mm[0.006--0.008in]
          exhaust----0.21--0.25mm[0.008--0.010in]
          hope this helps
          never ride faster than your gaurdian angel
          can fly
          1981 rh 5N5
          MIDNIGHTSPECIAL
          1188cc
          4 into 1 pipes with a transac muffler,
          as the motorcycling gods intended everything else stock std
          http://s856.photobucket.com/home/steptoexs11
          http://steptoexs11.webs.com/
          http://www.youtube.com/my_videos?feature=mhum
          1982 vf750 sabre
            Steptoe, those smaller clearances you show for the 80 models are also for the 81 models H, SH, and LH. Since it was for 80 and newer, I would think it would also be for the XJ, but do not have an XJ manual.
            • Yahman
              • Mar 2008
              • 779
              • Salem, OR
              82 XJ1100J Valve Clearance (Cold)
              Exhaust 0.008 - 0.010 in (0.21 - 0.25mm)
              Intake 0.004 - 0.006 in (0.11 - 0.15mm)
              Larry
              82 XJ1100
              80 XS1100G (Project bike)
              64 Yamaha YA-6
              77 Suzuki TS-185
              • greg maz
                • Feb 2008
                • 219
                thx evry1
                engine noisy at start up, I am still running 20w50 in cold conditions, could that influence?
                • Crazcnuk
                  • Aug 2006
                  • 2980
                  It certainly won't help, but it depends on WHAT is making the noise(s).
                  Some noise at startup is normal. It takes a few minutes for the motor to heat up, reducing clearances.
                  It also takes a bit to get oil circulating, more so if your using thick oil in cold conditions.
                  '05 ST1300
                  • Steptoe
                    • 175
                    valve clearances
                    if i thought i had tight valves the first thing i do is throw a compression test at the motor, that would tell you if they were riding or not,as long as the rest of your motor is good
                    can fly
                    1981 rh 5N5
                    MIDNIGHTSPECIAL
                    1188cc
                    1982 vf750 sabre
                    • Crazcnuk
                      • Aug 2006
                      • 2980
                      Only if you do the test while the bike is hot.
                      Even if they are tight, when cold you will get good compression, otherwise the bike wouldn't start at all.
                      Personally, I would just do the tune-up including checking the valves, and setting the cam chain tension,etc.
                      THEN, if it doesn't work go deeper.
                      '05 ST1300
