fairing removal
  • Filter
  • fairing removal
    i have a 79 standard with a full yamaha fairing. has anybody removed this and went to headlight and turnsignals on the fork. is it plug and play on electrical, what parts do i need to acquire any help would be appreciated.
    Tony Leeman
    79 xs11 f, touring
    adleeman@yahoo.com
    Lakeland, FL
  • #2
    It is plug and play on the electrical. you will need a headlight bucket, trim ring and headlight, the headlight mounting ears, headlight reflectors,front turn signals and the signal mounts that go on the forks.
    HTH
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • #3
      fairing removal
      do i have to remove the front forks....
      Tony Leeman
      79 xs11 f, touring
      adleeman@yahoo.com
      Lakeland, FL
      • #4
        Not to remove the fairing or bracket. Unbolt the fairing from the bracket and then remove the bracket. If the headlight ears are not on the forks then you will have to remove the forks from the triple tree to install them.
        Paul
        1983 XJ1100 Maxim
        1980 XS1100 Special
        • #5
          adleeman:
          See the below posting for the manual on fairing.
          http://www.xs11.com/forum/showthread...hlight=Fairing
          • #6
            many thanx
            thanx much that was very helpful
            Tony Leeman
            79 xs11 f, touring
            adleeman@yahoo.com
            Lakeland, FL
