Carb bodies
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Carb bodies
    I have a perfect set of carb bodies labeled 3J6 ('80 special?) and want to know if there is any difference between the US and Canadian models? Maybe some super guru knows?????
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Fun part is that I have a set of 3J6 carbs on my '80G, but we pretty much determined that they came off of a Special.
    My '80 Special, however has 3U9 series carbs. The only difference I noted, w/o having them side by side, is that the float bowls have a different drain system.
    The 3J6 bowl drain comes out the bottom pointed straight down and the 3U9 drain comes out to the side.
    Both use the plastic floats, no rubber plugs, 110 mains, 45 pilots, 185 air jet, and push in float seats.
    '05 ST1300
    • red bandit
      • 970
      • central michigan
      Sounds like you have an 80 carb (drain bolt vertical) and an 81 (drain screw horizontal). All parts will swap. Unless there is something diff. about a Canadian model but I don't think there is.
      79 SF parts bike.
        FYI, my stock pilots are 42.5 and not 45.
        • Crazcnuk
          • 2980
          Mine may be 42.5 as well, That is what they are supposed to be, but the ones in my other carbs were 45's, I don't know why.
          I have mains, pilots, etc up the ying yang, so that isn't an issue.
          '05 ST1300
            Some of us put 45 pilots in to, you know, "soup 'em up".
            • Crazcnuk
              • 2980
              Well, 45 pilots doesn't 'soup' anything up unless your running really big mains.
              However, rather than hijacking this thread, you can see the work we did on this here:
              '05 ST1300
              • Crazcnuk
                • 2980
                I think the float bowls may be off of an older series of carb (79?) as these bowls have the little bump for holding the rubber plug in the pilot tube, but these carbs are not cross drilled.
                '05 ST1300
                • planedick
                  • Mar 2005
                  • 2068
                  Pic
                  Here's what they look like....
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  • Crazcnuk
                    • 2980
                    Saw that picture over in the buy/sell area.
                    I meant the float bowls I have on my carbs, with the side exit drain, look to be late 79 or early 80.
                    I think that is when Yamaha used the cross drilled pilot tower with rubber plugs?
                    '05 ST1300
                    • planedick
                      • Mar 2005
                      • 2068
                      Float bowls
                      These carbs had such float bowls, but there was only two and I sold the other. These had plastic floats, push in needle valve seats with yoke & screw retainer and no rubber plugs.
                      Drilled airbox
                      Tkat fork brace
                      Hardly mufflers
                      late model carbs
                      Newer style fuses
                      Oil pressure guage
                        look identical to my 81 special carb bodies.
                        • XSPastor
                          • Oct 2007
                          • 602
                          • Gaithersburg, MD
                          ditto
                          They look like my 81 special carb bodies too.
                          Tim Ripley - Gaithersburg, MD
                          23mm float height
                          120 main jets
                          42.5 pilot jets
                          drilled stock airbox with K&N
                          Jardine 4 to 1 Exhaust
                          spade fusebox
                          1st and 2nd gear fix
