I just bought a Speedy Sleeve from Timken that fits over both ends of the crankshaft and creates a new surface for the seal to ride on, covering the small groove that has worn into the sealinig area of the crank.
The crankshaft end seals are: National/Timken 32x48x8 for the left sidfe, 32x42x7 for the right, and the sleeve is P/N 99128. It comes with the installing tool also. That's a big plus.The sleeve is a little pricey at $28 each, but it is worth the money to be rid of those oil leaks.
(Sold back to Maximan)
If that is correct, do I need 223240, or 223215?
