I'm curious to see how many XSives have had problems with the crankshaft versus transmission.
Common Problems Poll
61trouble with crankshaft failure.0.00%0trouble with transmission failure.32.79%20trouble with both crank and tranny.4.92%3trouble with neither.62.30%38Tags: None -
Yep, cooked the crank bearings after running low on oil in the N. Georgia mountains (59K). I ran that engine (79F) with straight 70W oil for another 25K until it finally gave up. Tranny gears, of course, probably most of us have.
Two motors ate crank and bearings, three motors have had trans troubles. (I think that's the count anyway.. ) This current motor has had the gear fix, but 1st is going out AGAIN.
I have an 80 SG and have less than 31,000 on the odometer-so far no major problems.Bike has been stored maybe 2 months outside the whole time i owned it under a cover.Rest of the time has been in garage or storage unit.No problems yet with transmission or crankshaft.Keeping fingers crossed.1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
Just Tranny troubles for me. My bike and my brothers bike. Mine was worse then my brothers and he has over 60k where mine has only 23k. Thank God for no Crank troubles.Chris
79 XS1100 Standard aka: Mutt
Gimme Fuel Gimme Fire!Comment
Transmission on my first, and third bikes. The trans on the third actually did a "lock-up" on me! I know it went into two gears at once, I just have NOT had the time to tear it down, as I'm trying to get a different bike going.
My midnight only has 22K on it, so it SHOULD go for at lest 30K more before I need to worry about the transmission. The one I've got apart had four TEETH missing of the MAIN SHAFT. This is the FIRST I've ever seen, so I do NOT know what the PO was doing, but it wasn't pretty!!Ray Matteis
My "F" and my brother's "E"... Mileage 50/60k-ish.
No engine or tranny probs."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
none of the above
however mine '80 XS11G >200K kms did smoke a little and the base gasket was leaking - the leaky base gasket prompted me to do a complete re-build - everything from the ground up - even wheel bearingsBryan H
"Conan, what's best in life?"
"To crush your enemies, drive them before you and the lamentation of their women"Comment
No engine or tranny probs. 55K79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
Only with one of the three.
Haven't had a lick of problems with the tranny on either the 80G nor the 82J. BUT, the 79F (bought w/out road test) quickly let us know, after re-doing the carbs, that second gear was not a happy place.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
Of all the Yammies I've had the only one to have any problems is my '82 Maxim.Its been well documented here for the infamous endemic tranny failure with approx.20000 miles on him over 24 years...never had crank problems.Last edited by madmax-im; 01-28-2009, 08:35 AM.2005 Honda SilverWing 600
2018 Honda PC-Xpress 150Comment
Hey there Elevenator,
Have you read up on the ride reports by the magazines in the articles section? The crank and it's flat shell bearings are very robust, designed to last many 10's of K miles. The trans regrettably was made with an inherent flaw in the dogs and slots.
I put approx 50K on mine before both 1st and then 2nd gear went out a few months apart. Parked for 9 years, then rebuilt trans, did little big bore kit WITHOUT checking or replacing rod or con bearings cause I didn't need to split the cases. That was in 2000. I don't ride it that much, but have put about 16K more miles on it, still no signs of crank problems.
T.C.T. C. Gresham
