Common Problems Poll
  • Elevenator
    Banned
    • 76
    • The nation of Change U can relieve in
    I'm curious to see how many XSives have had problems with the crankshaft versus transmission.
    61
    trouble with crankshaft failure.
    0.00%
    0
    trouble with transmission failure.
    32.79%
    20
    trouble with both crank and tranny.
    4.92%
    3
    trouble with neither.
    62.30%
    38
    • 8893
    Yep, cooked the crank bearings after running low on oil in the N. Georgia mountains (59K). I ran that engine (79F) with straight 70W oil for another 25K until it finally gave up. Tranny gears, of course, probably most of us have.
      Two motors ate crank and bearings, three motors have had trans troubles. (I think that's the count anyway.. ) This current motor has had the gear fix, but 1st is going out AGAIN.
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        well, if anyone needs a crank, I have a spare in the garage...
        I did the tranny fix, but I never use second gear anyway, so it did me no good.
        Ich habe dich nicht gefragt.
          • 2074
          I have an 80 SG and have less than 31,000 on the odometer-so far no major problems.Bike has been stored maybe 2 months outside the whole time i owned it under a cover.Rest of the time has been in garage or storage unit.No problems yet with transmission or crankshaft.Keeping fingers crossed.
          • ccogswel
            • Jun 2005
            • 302
            • Bowling Green, Ky
            Just Tranny troubles for me. My bike and my brothers bike. Mine was worse then my brothers and he has over 60k where mine has only 23k. Thank God for no Crank troubles.
            Chris
            79 XS1100 Standard aka: Mutt
            Gimme Fuel Gimme Fire!
            • adam79
              • 184
              • Tacoma, WA
              tranny
              just 1st gear issues with my tranny. this happened around 56k miles.
                • 7818
                Transmission on my first, and third bikes. The trans on the third actually did a "lock-up" on me! I know it went into two gears at once, I just have NOT had the time to tear it down, as I'm trying to get a different bike going.
                My midnight only has 22K on it, so it SHOULD go for at lest 30K more before I need to worry about the transmission. The one I've got apart had four TEETH missing of the MAIN SHAFT. This is the FIRST I've ever seen, so I do NOT know what the PO was doing, but it wasn't pretty!!
                • prometheus578
                  XS-XJ Super Guru (RESIGNED)
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  My "F" and my brother's "E"... Mileage 50/60k-ish.
                  No engine or tranny probs.
                  • aussixs11G
                    • 76
                    • Brisbane Australia
                    none of the above
                    however mine '80 XS11G >200K kms did smoke a little and the base gasket was leaking - the leaky base gasket prompted me to do a complete re-build - everything from the ground up - even wheel bearings
                    Bryan H
                    "Conan, what's best in life?"
                    "To crush your enemies, drive them before you and the lamentation of their women"
                    • red bandit
                      • 970
                      • central michigan
                      No engine or tranny probs. 55K
                      79 SF parts bike.
                      • Bigfoot
                        XS-XJ GURU
                        • Sep 2005
                        • 1422
                        • Kansas City, Missouri
                        1st gear out on the xj and the midnight special both when I aquired them.
                        Harry
                        '79 Standard
                        '82 XJ1100
                        '84 FJ1100
                        Acta Non Verba
                        • Cobia
                          • Jul 2007
                          • 1587
                          • Palm Beach County, Fl
                          Only with one of the three.
                          Haven't had a lick of problems with the tranny on either the 80G nor the 82J. BUT, the 79F (bought w/out road test) quickly let us know, after re-doing the carbs, that second gear was not a happy place.
                          1980G Standard, Restored
                          Kerker 4 - 1
                          850 Rear End Mod
                          Automatic CCT
                          1980GH Special, Restored
                          '82 XJ1100 (Sold)
                            • 6763
                            Of all the Yammies I've had the only one to have any problems is my '82 Maxim.Its been well documented here for the infamous endemic tranny failure with approx.20000 miles on him over 24 years...never had crank problems.
                            2005 Honda SilverWing 600
                            2018 Honda PC-Xpress 150
                              Hey there Elevenator,
                              Have you read up on the ride reports by the magazines in the articles section? The crank and it's flat shell bearings are very robust, designed to last many 10's of K miles. The trans regrettably was made with an inherent flaw in the dogs and slots.
                              I put approx 50K on mine before both 1st and then 2nd gear went out a few months apart. Parked for 9 years, then rebuilt trans, did little big bore kit WITHOUT checking or replacing rod or con bearings cause I didn't need to split the cases. That was in 2000. I don't ride it that much, but have put about 16K more miles on it, still no signs of crank problems.
