Spark plug cap replacement
  • FANNING507
    • Jul 2008
    • 103
    • south central Kansas, Turon
    I've searched the thread and didn't find any help. I have Original equipment caps/resisters on my bike. The replacements have a slot for a screwdriver to tighten. Are the old plug caps to be clipped off, or is there a trick to remove them? Maybe a dumb question, but I've looked all over for an answer. It almost looked like a metric allen wrench would work, but it doesn't. It doesn't look like a torx setting either. Appreciate any help. (81 XS1100 LH-MNS) Kim
    '81 XS11 LH (MNS)
    "On a scale of 1 to 10, I have an eleven!"
    "Excess is easier to say than XS,"
  • tarzan
    • 1700
    • Chandler,Az.
    You should be able to unscrew the caps off while pulling gently.And you may still need to cut a liittle off the end of the wire to get a good connection .
    80 SG XS1100
    14 Victory Cross Country
      • 7766
      The spark plug caps just unscrew. Turn counter clockwise on the cap while holding the wire as tightly as you can. I find about ten turns and then just pull off. Once you have the old one off, clip about 1/4" off the wire, so the new cap will have a clean wire to connect with.
      HTH
        Just Curious
        Does anyone have a picture of one of these taken apart? Be interested to see where the break is, and what part is threaded where.
        • SFerinTEXAS
          • Jun 2006
          • 877
          DiverRay said it pretty straight forwardly . The cap has an internal threaded post inside it that screws into the wire core . Just follow the directions he offered and it will be obvious to you when the cap unscrews from the wire.
          79SF
          XJ11
          78E
            • 8798
            spark plug cap picture
            Cap for cyl 2-3 disassembled, comes apart with a flat head screwdriver. Note the small resistor. Cap for cyl 1+4 didn't have a slot to disassemble.
              Thanks
              Thanks for the pic Phil and the info. The mtal piece was on the end of the wire? that threads into the boot? Just checkin because I may try the cutting the wire back fix to see if that is my problem. Not having done this before I hate to pull when I should have twisted on something.
                • 8798
                cap
                No, the metal piece in the picture is what attaches to the spark plug itself. You don't really need to take this out unless mabye to test/clean the resistor. The spark plug wire just unscrews from the cap, very simple.
                • FANNING507
                  • Jul 2008
                  • 103
                  Spark plug cap
                  Hey guys, thanks a bunch. I never dreamed they just screwed on! With all the other electrical connections on the bike; that's a first for me! Kudos--I really appreciate the help. Now this is in the archive of knowledge. Thanks. Kim
                  '81 XS11 LH (MNS)
