Rear springs
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Rear springs
    I would like to change the springs on my progressive shocks. They bottom out enough to want a change. I have new springs but am wondering if it's better to let a shop do it or is there a jig I can make or tool I can buy. I did a seach but there is not much on changing rear shock springs.
    BDF Special
    home made spring compressor
    This one I made myself and it works great. You can also add a spacer and a washer or two in between the spring and preload adjuster to beef up the spring.
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      Nice idea there, BikerPhil!
