(muffled remarks and a couple'o clandestine thuds)
William,
The Stop/Tail/Turn wires look okay. You can ground the lights to the frame or to the Black wire; your choice.
If the Turn Signal lights are different brightness when using the 5-wire connections and the 3-wire connections then the connectors are dirty or the ground connection is bad.
In your picture:
The Red wire is unswitched 30 Amp fused power direct from the main fuse and the battery. It runs any accessories that need power even when the Ignition switch is Off.
The Blue wire is switched 10 Amp fused Headlight power from the Headlight Relay to the instrument lights and to the Reserve Lighting Unit (RLU)
The Brown wire with the Light Blue snap-on connector is switched 20 Amp fused Signal and Auxiliary power to the front brakelight switch. The Auxiliary power connector has been broken off and replaced with the Light Blue snap-on connector.
At this time it is unlikely that the rear blinker and headlight problems are related. Did you test the Headlight Relay? It's up toward the very front of the frame underneath the fuel tank.
Before you cut and splice any more wires, here is a link to a color schematic for the 1980 XS1100G Standard. Take a look and see what you can find! http://www.xs11.com/forum/showthread...olor+schematic
For example:
The Red, Blue, and Brown wires in your photo are shown in the lower left corner.
The Headlight Relay is shown in the upper middle section.
The Reserve Lighting Unit (RLU) is closer to the upper middle right section.
Both the rear 3-wire Turn Signal connections and the 5-wire Stop/Tail/Turn Signal connections are shown at the right hand edge of the schematic.
Have fun!
![Smilie](https://xs11.club/core/images/smilies/smile.png)
Regards,
Scott
William,
Originally posted by whoride76
View Post
View Post
View Post
For example:
Have fun!
Regards,
Scott
