I took my clutch apart today. Not what I expected. There were 9 steel plates and all 8 friction pads were between 2.4mm-2.5mm. This is my first time viewing these parts (not new out of a package, but old out of the bike) and they dont resemble any pictures I've seen. The friction plates were all dark red, and the steel plates all have a worn copper-ish glaze...all 9 of them, haha. Then, as I was looking at the part catalog, the clutch boss assembly has a total of 3 plates (seat plate, cushion spring, plate) and then the retaining wire ring. When I look at my clutch boss assembly, it does not look like I have all these parts.
1: Should I take the ring off and check? Can you guys tell from looking at it?
2: Is the discoloring on the steel plates normal, or should I replace them all? (just 7, not all 9)
