motor mounts
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    motor mounts
    i found a poly insert that fits nice i had to resize the outside of the bushing a little i used a carbide bit in a die grinder but a dremmel will work fine i had to burn the rubber off the old mounts but since they were so old it was easy the poly that i found are energy susp a-arm bushings for a 1988 dodge D-50 the number on the bushing is 2035 as they say a picture is worth a 1000 words
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      that is an excellent idea
      Ich habe dich nicht gefragt.
        Who is the manufacturer of the bushing? Moog?
        • mxmikie
          • Aug 2008
          • 482
          • Bouse az
          energy suspension the bushing is poly urethane and you can get it in diff colors i buy lots of bushings on ebay all the time i have buckets of urethane bushings so every time i need a bushing i just go through the buckets and is seems like i always have what i need and since they put a number on the bushing i wright down what i use it for
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Another way
            I cut a peice of shrink tube to the proper length and shrunk it on the old bushing. Took up the play and made a snug fit again.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
            • 81xsproject
              • 3185
              • Fortuna, CA
              That is awesome, mx. Definitely something I will be looking into.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • randy
                • Dec 2003
                • 4521
                The rubber mounts are there to dampen and isolate the engine vibrations. Why would one want to transfer vibration to the frame?
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  Same reason they have vibrating beds in those hourly rate hotels?
                  • randy
                    • Dec 2003
                    • 4521
                    I dunno, maybe the ladies will chime in here
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      I think the point is to help support the frame. Maybe Chop will chime in and tell us if his aluminum mounts made a difference in that area.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • Jerry
                        XS & TRUE XJ GURU
                        • 3023
                        • Elma, IA.
                        As with all things, motor mounts are a compromise. Softer mounts reduce vibration to the frame, but allow the engine to 'flex' a bit. This causes handling issues; the XS11 has sometimes been described as having a 'hinge' in the frame, lessening the quality of handling due to to-soft mounts. Solid mounts will improve handling by making the engine/frame combo more rigid (like 1 piece) but decreases rider comfort by transmitting more vibration into the frame. The OEM mounts are designed more toward rider comfort than handling, but this impression may be due to having old mounts!
                        I like the idea of finding good replacement engine mounts. One hopes that the newer technology bushings will improve handling without increasing objectionable vibration. This is an excellent tip.
                        Jerry Fields
                        '82 XJ 'Sojourn'
                        '06 Concours
                        My Galleries Page.
                        My Blog Page.
                        • mxmikie
                          • Aug 2008
                          • 482
                          • Bouse az
                          i also did the xs 750 diff swap along with the poly motor mounts i have replaced rubber mounts/bushings in all my cars and bikes for the last 25 years i think the i is far better than the rubber counter parts the vibe is so small that after 1/2 months you don't notice it any more the diff swap to the xs 750 is a 5/600 rpm drop per gear the rpm diff will make up for the poly mounts ........
                          • DeanR
                            • Jan 2005
                            • 1499
                            • Finger Lakes NY
                            mxmikie, Good tip and pics. Thanks.
                            Now for sentence construction for easier reading?
                            80 SG
                            81 SH in parts
                            99 ST1100
                            91 ST1100
                            • mxmikie
                              • Aug 2008
                              • 482
                              • Bouse az
                              sory i went to publik scool
