starter free wheels
    • 2117
    Mine did the same thing Sunday-I changed the solenoid and it seemed to have solved the problem.Started bike up yesterday-no problems.Running 20 W 50 Castrol Oil.
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      Starter not engaging
      My bike was doing the same thing this year anytime the temp went below 0C (32F) at night . I had the 20w50 in it .
      Last year I ran 10w40 all year and had no probs .
      Next year its 10w40 in the Spring and Fall and 20w50 in the summer . Also the first thing I'll do when it comes out of storage is dump the new oil I put in when I put it away .
      XJ1100K
      Avon rubber
      MikesXS black coils
      Iridium plugs w/ 1k caps
      MikesXS front master
      Loud Horns (Stebel/Fiamm)
      Progressive fork springs
      CIBIE headlight reflector
      YICS Eliminator
      • Brent
        • 959
        My fix?
        Cold Cranking Amps. A fully charged car battery's worth of them.
        Fredintoon is right. A really good charged battery will sling those clutch things out harder - engaging the motor to spin.
        A weak battery contributes to problem; whirrr.
        Brent in GA
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          Extra ground cable
          I wonder if the extra ground cable from the starter casing to the battery gound cable a la Randy would help the CCAmps ? I plan to install this as soon as I get the cable .
          XJ1100K
          Avon rubber
          MikesXS black coils
          YICS Eliminator
          • boyat68
            • Oct 2007
            • 358
            • Virginia
            Axel:
            You can never have too many grounds so one more cannot hurt. I think the problem lies in the grounds are the first place to suffer corrosion. One thing that will definitely help is to re-clean the battery post and clamps periodically.
            • randy
              • Dec 2003
              • 4521
              Extra ground cable
              All I can say is it helped me a great deal.
