XJ Rear Mastercylinder
    I have had nothing but problems lately with my rear M/C. I have tore it apart a couple times and polished up the piston and cleaned the O-ring and the groove it sits in. I have cleaned the spooge hole MANY times, yet I continue to have inrtermittent problems with the brakes not releasing all the way. So I went to my parts bike to check out and see how bad that one looked. Hmmm.. The caliper actually looks better than mine, and the M/C?? What's this? No proportion valve? It looks different! Apparently the previous owner had installed an XS M/C. John and I had looked at this and discussed it before, and it appeared the mounting tabs would have to be cut off and re-welded. Maybe this one is an aftermarket?
    Anyway.. got the M/C, line, and caliper all swapped out.The XJ's M/C is a 3/4" and this one is only a 1/2", but it locks up the rear tire on command easily. My question is.. the XJ's M/C has two wires coming out of it for a brake fluid level sensor. Can I make a pigtail wire and just connect these two wires to turn off the brake light on my dash, or was there some sort of resistor in this and it will short it out if I do it that way?
  • ossjughead
    • 203
    • Ottawa, ON
    If you run a ground to one of them wires it will turn off the light in the dash thats how i fixed mine anyways. Do you know if anyone is making a aftermarket rebuild kit for the rear master for the 82 xj yama still make one but its 80 bucks here
    http://i69.photobucket.com/albums/i7...all2008017.jpg
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      Checked the wiring diagram
      Hey trbig,
      I checked the diagram in my factory service manual and I found that both those wires are just in line with the front mc wires. No resistors, relays or anything else in that circuit.
      Since my clutch switch was broken, I just taped the two wires seperately with electrical tape and have had no probs.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
