Look What I Found !!!
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    That's motorcycle porn!!
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
      • 8635
      oil pressure sensor
      Mitch, all stock 78-81 XS models use an oil pressure sensor with no float in the pan for oil level, just a sight glass. 81 and up XJ's have the oil pan with the float for oil level.
      โ˜ฎ
      • GrandPrix46
        • Mar 2008
        • 66
        • Converse, TX
        4.2 quarts oil tank capacity? I've been going with the 3.7 quarts like the service manual says with filter change for my SG, do I need to add oil? I don't have an oil cooler and the SG in the ad doesn't look like it has one either. Which one is right?
        You just pour in a set amount of oil? Go by the sight glass, it's full when the oil is in the center of the glass.
        '07 Virago
        '80 XS11G
        '78 XS11E
        '97 Grand Prix GTP
        '99 Grand Prix GT
        • Montreux_Blue
          XS-XJ Guru (Deceased)
          • 1143
          • Longitude: -85ยฐ 57' 43" Latitude: 37ยฐ 52' 55"
          I have always bought the service manual for whatever I drive/ride and go by what ever it says within reason. I'm one of those by the book kind of guys.
          Famous Myspace quote:
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            For sure
            I know for sure that the '78 & '79 standards have an oil pressure light.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
              Yep,
              78-81 XS's have an oil pressure light. The light also doubles as a brake light warning light...if the brake light filament is burned out, the oil light comes on also.
              The 82-84 XJ's have the oil level sensor instead, but no pressure sensor. IMHO, I would rather have a pressure sensor than a level sensor!?
                • 8635
                Standards, no light checker unit, no bulb warning indicator for the tails.
                โ˜ฎ
                • DJinNH
                  • Mar 2008
                  • 854
                  • New Hampshire
                  When I bought the '81 XS1100SH last Jan...a host of parts and things came with the bike.One of which was the Clymer svc.manual.Dont know how I overlooked this...but tonite when thumbing thru the Clymer I found this folded in the back...
                  These photos bring back some memories, me around 18 and just staring at them dreaming of having one some day. When Dad and I ordered our '81 850 Special (we went in 50/50) in the fall of '80, it was torture waiting until Spring to finally ride it. Never thought I'd own an 1100 back then.
                  Sometimes it's beneficial to be much older.
                  Don
                  currently own;
                  1980 Yamaha XS1100 SG
                  2009 Yamaha Star Raider
                  • John
                    • 5117
                    The XS11 does have an oil pressure light, and the switch is located just below #2 & 3 carbs, right behind the cylinders and in front of the starter.
