View Post
After investing in new springs, steels, and frictions and talking to one of the mechanics at the dealership yesterday I'll just bite the bullet and buy a new Pressure Plate 2 and be done with it. Apparently there are no dimensions given because the part is considered more of a consumable item that is replaced when a clutch is changed. Replacing a part that has no specified initial dimensions or service wear limit makes me uneasy.
Moving right along: NW Vintage Cycles claims to have a new pressure plate 2, part# 2H7-16325-00-00 for $31.65. That parallels your search, T.C., that found one for $29.50 a few years ago.
Everyone else wants more; I blame Johnny Depp:
Local Yamaha dealer: $52.57
Boats.net: $47.61 + shipping
SpeedSupplies.com: $60.39 + shipping
Yo ho! Yo ho!
Originally posted by Ivan
View Post
View Post
A steel won't fit onto Pressure Plate 2
There are no misalignment marks on Pressure Plate 2 nibs or the splines on the Clutch Boss Assembly
The splines on the Clutch Boss Assembly and Pressure Plate 2 have no unusual wear
Some additional thoughts about adding an extra steel to a non-worn clutch assembly:
The nibs on Pressure Plate 2 are only 0.080" or 2.032mm
OEM clutch pack exposed spline height is 0.115" or 2.921mm
OEM clutch pack exposed spline height with extra steel is 0.035" or 0.889mm
With an extra steel added to the clutch pack only 0.035" or 2.032mm of the splines on the Clutch Boss Assembly will engage the nibs on Pressure Plate 2. The pressure plate can pop out under load and try to rotate like the gear dogs/slots in the transmission. That would round the ends of the Clutch Boss Assembly splines and Pressure Plate 2 nibs and strike clutch springs and posts. If the pressure plate stayed rotated and the nibs 'hung' on the ends of the splines the clutch would not release.
Okay, that is more than enough clutching, it's time to go pull the oil pan and see what other mischief has been wrought!
Regards,
Scott
