Broken cam chain equals bent valves?
  • newc4
    • 642
    • Vienna VA
    I'm considering picking up a SF with a broken cam chain. The ad says that "Blew the cam chain, not sure why! I didn't hear any noise at all when it blew".
    What are the chances that some of the valves are bent? If so, what do I need to replace, besides valves, and what is the availability of parts?
    Thanks,
    Darrell
    Darrell
    78E
    80G project
    06FJR
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    If the cam chain busted when the engine was running, I'd say the chances are about 100% that some(all ) the valves were bent. A compression check is the best way to tell without disassembling.
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      Just read the rest of your question...
      If the chain broke with the engine running at high rpm, there could be damage to internal parts like the chain guide, chain tensioner or the cam and crank sprokets. You should be able to find the parts. I think Vesra still makes the valves and there are plenty of guys parting these engines out on fleabay. I'm sure others with chime in with their opinions/experiences...
      23mm float height
      120 main jets
      42.5 pilot jets
      spade fusebox
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        I hate typos...
        23mm float height
        120 main jets
        42.5 pilot jets
        spade fusebox
          Hi Tim,
          if the camchain is broken the camshafts won't turn and some of the valves will be held open. Spin the motor like that and a held open valve that isn't bent soon will be. OK, remove the camshafts so all the valves will close before doing a compression test? With no air getting in you won't get a good reading anyway. I don't see any guaranteed check short of pulling the head.
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            Hey Fredintoon,
            Duh! You're right!! Of course you can't do a compression check with a broken chain! What the heck was I thinking? I'm going to get another cup of coffee.
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              Valves can be found.. new or used.
              Vesrah makes a gasket set... you'll need a new head gasket after pullin' the head to replace the valves.
              And yeah, ya probably have a few bent ones.
              Shouldn't really be anything more damaged other than the valves.
              Ok, maybe a "valve nick" on the top of a piston.
              Need a new chain and master link, too.
              • egsols
                • Jan 2006
                • 1090
                • Barrie, Ontario, Canada
                Having heard the comments, I hope the price is right.
                Ernie
                  If the engine was running at even just a fair rpm, the speed of the pistons slamming into the valves would be substantial, and there can also be damage to the valve guides, a bit tougher to replace than just the valves themselves!? Good Luck!
                  • Poprock
                    • Apr 2005
                    • 594
                    • Oregon Coast
                    The shoulder bolts backed out of the exhaust cam sprocket on my bike, just as I pulled up at a stop sign. Bent one intake valve. No other damage. Swapped in a valve out of another head, lapped it in. Motor seems to be fine. I'll know more when the carbs are cleaned up. I suspect the fix won't be too severe.
                    • Toolmaker Tim
                      • 671
                      • South Bend, Indiana
                      Bent Valves
                      Darrell, Cycle Recycle 2 in Indianapolis, In is where I got my replacement valves for the 2 bent valves, plus the two I bent setting the camshaft-valve shim clearences. The prices were pretty reasonable and service was quick. Just my $.02. The job isn't as hard as I made it for myself. While you are in there you might want to replace the valve seals. Good Luck. Tim
                      1979XS1100SF
                      K&N's and drilled airbox
                      Jardine 4in1
                      Dunlop Elite 3's
                      JBM slide diaphragms
                      142.5 main jets
                      45 pilot jets
                      T.C.'s fusebox & SOFA
                      750/850 FD mod.
                      XV 920 Needle Mod.
                      Venture Cam Chain Tensioner
                        A chain breaking while riding could cause some problems. The cams aren't going to immediately go from 3k rpm to stop.. so they may indeed all be bent. The chain could have become balled up in the bottom of the motor and bent/damaged the crank sprocket or even cracked the case slightly before the motor stopped spinning completely... but it's pretty doubtfull.
                        andreashweiss on here can probably set you up with a "Newsed" complete head at a really reasonable price.. or just the valves. Worst case scenario.. I think there will be bikes for sale a plenty this winter. Keep your eyes out for a good used motor on a parts bike and swap the whole shebang.
