Rear shock absorber adjustment
  • Rayford
    • 4
    Hi,I have a 1980 xs eleven special and it has adjusters on both sides of the rear shock,they have numbers.I am about 200 lbs and my wife is about the same. I guess my question is : The lower the number the stiffer or vice versa?? or does somebody know the best settings for this application?
  • Rayford
    • 4
    That is with both of us on it of coarse
      • 8891
      shock adjustment
      More weight, higher the number. The spring preload can be adjusted too at the bottom of the shock.
        I know the XJ shocks are different, but I'm about 250+ (Depending on before or after I eat!.. lol) It's a bit stiffer ride.. but I play more than most I think. I don't want a smooth soft cruising feeling.. I want to feel all the bumps in the road. I don't know what pre-load it would equal.. but I keep about 40psi in my rear shocks and the dampener on 4. I've bottomed out a few times on lesser settings...that hurts... but you probably aren't supposed to jump these bikes either.. lol.
