Axel & bikerphil-thanks for keeping me going. How did TC make that diagram? its the same one thats in the back of the factory service manual, but colored. Amazing.
Anyway, got the headlight housing out-once I gingerly got the plug apart I found the problem-mondo corrosion on the hot wire to the ignition switch-it also look a little burned? probably from a jump at some point I guess. After using some contact cleaner, and applying a bit of dialectric grease, I had a nice christmas tree of lights between the speedo and tach.
Hit the starter button, a resounding click from the relay, but no starter. Cleaned and greased the two large lugs, filed down to clean metal, After a couple of hits on the starter it spun over nicely.
So now I'm really getting excited-maybe it will start? clhoke was very, very stiff, oiled it to free up its movement, put the petcocks to prime-and gas runs all over the left side. PO had disconnected the fuel line. rechecked everything (the petcock vac line was off too), set to prime and was rewarded with a bit of fire. General messing about occured-I used starter fluid ONE time after removing the bottom of the airbox, just a tiny bit and it seemed to help it. After a bout an hour of messing about it will crank and run on the two right cylinders (hot pipes on that side, cold on the left two) for about three seconds then stall. What success.
I pulled a plug on each side-checked that the left outermost plug had spark the old fashioned way (ground plug to block and turn over)-it did spark. The right side plug smelled a bit gassier than the left, otherwise there was no difference.
Any ideas? at this point I'm thinking I'm going to have to pull the carbs. The PO says they were cleaned, but I'm having a hard time believing anything he said at this point. The stiffness of everything, the nearly bad ground, etc. makes me wonder. He said he rode this bike after a carb cleaning, until it went dead. I suppose he could've. But usually running only on choke and not hitting on all cylinders that have spark means dirty carbs.
Any other good troubleshooting ideas for the two left side cylinders? Was thinking coil, but it did have spark. I also tried both the TDI units I have, both ran the bike the same way.
OH, the rear brakes have the same disease at the fronts-gonna have to diassemble that caliper and MC too. And I need to order the fusebox from TopCat, mine is fragile to say the least.
Thanks again for all the help.
[/IMG]
