Hey guys I like the z rated tires... is there a z rated tire out there that will fit the stock 19" front wheel of our beloved xs? without dragging the fender bolts?
Tire sizes
Why Z rated?
H rated tires are specified for most, if not all, XS'es but V rated tires are available which should be good for well past the top speed of our machines.
I have been running Metzler Lasertec tubeless 110/90V-19 on front and 130/90/V-16. Compound is a bit soft but they are prety sticky on the roads. I usually use 2-3 rears for every front but then, I have this right hand twisting problem thingy.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can. -
new tires
Hey Scap, the rear Radial tire that you will use will improve the handling of your 11 by leaps and bounds.As for the front I don't see why a radial tire can't be found for the stock 19" rim ..BTW, Did you go 170 or 180 for your rear rim?MDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
Radials?
Hey XSChop,
Can we run radials on these bikes eventhough they call for bias ply tires in the specs?1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
radials
I am not positive about the stock front 19" XS rim able to take a radial. Scappod converted to chaindrive and has a wider rear rim which will greatly improve handling, tire choices....MDRNF
79F.....Not Stock
rear tire/radials
The rear tire I have on right now is a 170/60/zr17 I can go 180 and i got the go ahead from a GOOD mechanic to run the road attack 110/80/z19 for the front so it should be much betterEgo Sum Meus Frater Custodis...Comment
The Shaft
How do you get a 170 size rear tire to fit without hitting the shaft drive?Second Star To The Right...And Straight On Till MorningComment
Radials vs bias-ply
on a sidecar rig there's just 2 things needed in a tire:-
That it holds air.
That it has some tread on it.
But I have other bikes that I ride solo and may need to know this.
Is there a difference in the rim configuration that won't allow a radial tire to fit on a rim designed for a bias ply tire or vice versa?
Are there differences in handling characteristics between the two styles of tire that could prove hazardous?
Buddy rides a 1200 Kawi that came with radials from the factory and they wore away so quick that he replaced them with bias ply tires that have now got two riding seasons on them. And he ain't fell off yet.Fred Hill, S'toon
"The Flying Pumpkin"Comment
☮Comment
Trying not to have a "Biased" opinion!
Hey Fred,
A quick search for "radial tires" revealed 25 threads, but this one has several replies from several very knowledgable folks and I value and respect their opinions on this! And there's also Pggg's comments!
Radial Tire Thread
From what I've read and seen, the Dunlop Elite III's are very close to a radial design/pattern, but also come in Bias Ply format for older bikes/rims!
T.C.T. C. Gresham
A 130 or perhaps a 140, if you're lucky, is the biggest you're gonna fit on these 11's.
