My XJ spit the plug!!!
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Fortunately it was the plug/cover for the timing chain adjuster mechanism. And of course it's dripping oil over the front of the engine.
    Can this plug be purchased anywhere?
    Or better yet, being the creative bunch that you are, what makes a good substitute for that plug? What do you folks use? I know I'm not the first one this happens to.
    Thanks
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
  • randy
    • Dec 2003
    • 4521
    The plug is available through bikebandit. You'll have to clean all traces of oil from the tensioner before replacing it or it will leak again. Some guys use silly-cone, some use JB Weld (!).
    I replaced mine 3 yrs ago with the OEM seal and used permatex gasket sealer. No leaks yet. (fingers crossed here)
    • Cobia
      • Jul 2007
      • 1587
      Many thanks, Randy.
      Going to the Bandit right now.
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      '82 XJ1100 (Sold)
      • randy
        • Dec 2003
        • 4521
        Cobis,
        While you're there, order the o-ring for the lock screw.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          One of mine has a small freeze plug pushed in the end of it.
          For those that don't know or are confused by the terminology, a freeze plug is what is put in the jacket of a water cooled engine to seal up the casting holes. Supposedly, they pop out if the coolant freezes keeping your block from cracking. I have never seen this happen. A cast iron cylinder wall is weaker than a stamped sheet metal plug. Go figure.
          Looks like this:
          Ich habe dich nicht gefragt.
            • 8795
            tensioner leak
            I stuffed a rubber stopper in mine.
            • Cobia
              • Jul 2007
              • 1587
              Randy,
              I wish you would have chimmed in earlier. I ordered three of the plugs. Let me see if I can modify the order.
              Kerker 4 - 1
              850 Rear End Mod
              Automatic CCT
              '82 XJ1100 (Sold)
                • 8795
                o-ring
                Hey Robert, you can get that o-ring anywhere, auto parts store or hardware store.
                • tarzan
                  • 1700
                  • Chandler,Az.
                  I bet you could tap it with a pipe tap and just screw a stainless plug in it.
                  jat
                  80 SG XS1100
                  14 Victory Cross Country
                  • Ken Talbot
                    • 4251
                    • Revelstoke, BC
                    Buy yourself and SWMBO a nice bottle of champagne. Pop the cork and save it for later. Drink the champagne and have a nice evening. Cut a disc off the small end of the cork and cut/file/sand it down to be a snug fit in the adjuster housing. Clean out the end of the adjuster body really well with a bit of acetone on a q-tip. Glue the disk in with a dab of silicone. Wallah!
                    Ken Talbot
                    • prometheus578
                      XS-XJ Super Guru (RESIGNED)
                      • Aug 2004
                      • 4012
                      • Olympia , Wa.
                      I know I'm posted it before....
                      On the road repair; hose clamp and a piece of wire.
                      • Cobia
                        • Jul 2007
                        • 1587
                        You see, I knew it!!
                        I knew that this was not an uncommon problem, and that there would be as many unique solutions to it as there are folks who've dealt with it.
                        I just didn't know about temperature tolerances, etc.
                        Thanks
                        Kerker 4 - 1
                        850 Rear End Mod
                        Automatic CCT
                        '82 XJ1100 (Sold)
                        • jrplumber1
                          • Sep 2008
                          • 60
                          • North Dakota
                          Stabil Cap
                          I used the smaller of the two caps on a container of stabil and some silicone. Now it looks like a small dial adjuster or something to that effect! Ive had no problems with heat so far. Just need to make sure you clean all traces of oil off the darn thing or nothing will stick to it.
                          Thats just my 2 cents worth.
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            stock plug
                            Odered the plug from Yamaha . Cleaned the area with carb cleaner . Re-installed with black RTV . Ees Good
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            Iridium plugs w/ 1k caps
                            MikesXS front master
                            Loud Horns (Stebel/Fiamm)
                            Progressive fork springs
                            CIBIE headlight reflector
                            YICS Eliminator
