Here we go again with ...Winterization
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    I noticed Ron's Tech Tip has tire pressures above spec for storage but a lot of other sites have you redicing the pressure 20%.
    Please share on this and other winterization tips.
    One of my favourite informative sites :
    Maximum Maxim-X: 1985-86 Yamaha 700/750 Maxim-X - All you ever wanted to know about the Maxim-X (Yamaha,750,700,Maxim,Maxim-X,XJ750X,XJ700X,XJ750,X700,1985,1986).
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Clymers Sez
    Well I dont winterize since it really doesnt get that cold in Louisiana and I do ride during the winter. Alot of what the linked article had makes sense so I decided to see what my clymer manual said about winterizing the XS.
    1. Wash bike and wax all painted and polished areas including chrome.
    2. Run engine 20-30 minutes to stabilize oil temp then change oil and filter and fill with normal amount of oil.
    3. Remove battery and coat terminals with petroleum jelly. Store battery in warm area and recharge every two weeks (must have been written before the advent of battery tenders).
    4. Drain all fuel from tank, hoses and carbs and leave cocks in reserve position. Or as an alternate, add satbilizer to full tank.
    5. Remove spark plugs and add a small amount of oil to each cylinder and turn motor a few revolutions by hand and then reinstall plugs.
    6. Tie or tape plastic over outlets of exhaust system to prevent entry of moisture.
    7. Check tire pressure, move machine to storage area and store up on blocks with wheels off the ground.
    8. Choose a place where moisture will not be a problem during storage.
    Doesnt say anything about actually covering the bike during storage. Then it says before starting in Spring, remove spark plugs, squirt a small amount of gasolie into cylinders to remove the oil coating. Install plugs but do not connect plug wires. Turn motor over a few times and then reconnect plug wires and start engine.
    Sounds like alot of work but in reality is not really that much to do.
    Mike Giroir
    79 XS-1100 Special
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      Blue Giant Sez
      1- Open front door.
      2- Drive motorcycle(s) into living room.
      3- Close front door.
      4- Start bike(s) periodically.
      5- Wait for Spring
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
      • MrOzz
        • Aug 2008
        • 782
        • Massachusetts
        Originally posted by blue giant
        1- Open front door.
        5- Wait for Spring
        Blue - Please speak to my SWMBO. What I told her was "Its better for the bike". Since Ive put some good money into it so far. SWMBO is not going for it.
        LOL
        Ozz
        1980 XS 1100SG
        Dyna 3 Ohm Hi Output Coils
        Pod Filters
        DynoJet Kit
        T.C.'s Fuse Block
        V-Max Auto CCT
        • webbcraft2150
          • Sep 2002
          • 1605
          • AUSTIN.TX
          I have never been a real fan in draining all the fuel out. Gaskets and o-rings tend to dry out. Back "when" I had to lay my boat up for months, I used a mix of Sta-bil, MMM and Sea Foam. I would run the engine till it started smoking alot and then shut er down. I would over treat the fuel in the tank with Sta-Bil. Always seemed to fire right up in the spring. I still use this method even though we still boat thru the winter, just not as much. I always made sure the tires on the trailer were fully inflated and would think the same would hold true for bike tires. Pulling the battery and stashing in a warm place and keeping it charged is paramount to having a good battery in the spring. I even pull the seat and stash it in the house somewhere. Don't forget to plug up the air intake on the air box.
          "Course the parking the thing in the house would be best. I actually did that with my Norton in the winter, but then again I was single. Best looking piece of furniture in the house.
          • tarzan
            • 1700
            • Chandler,Az.
            Blue Giant your my hero now.I wish I could do that.
            80 SG XS1100
            14 Victory Cross Country
            • egleaves
              • May 2007
              • 441
              • Sacramento
              I was wondering if anyone actually stored their bike in the house. If I were not fortunate enough to have an attached garage, I would definitely bring mine inside. The handle bars would make a nice coat rack.
              I know this, because Tyler knows this.
              1980 SG
              3J6 003509
              Kerker 4-1 (sans baffles)
              Fuse Block Upgrade
              Mike's XS Green Coils
              Pods w/Homemade Velocity Stacks
                The part that would scare me is the "4- Start bike(s) periodically". I don't thing my CO detectors would be too happy about that in the house
                • latexeses
                  • Jun 2008
                  • 1491
                  • California
                  Open front door , drive bike inside....
                  Just think of all the time that would save in the spring.
                  All the little things you want to do to the bike could be done durring the football games. Save a bunch of riding time in the spring.
                  Everything on hold...
                  • blue giant
                    • Aug 2007
                    • 880
                    • Ontario, Canada
                    I wish I could too!
                    Paul
                    1983 XJ1100 Maxim
                    1980 XS1100 Special
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      visiting privledges
                      I keep mine in a friends barn so I can visit if I want to . It is heated slightly all winter.
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • blue giant
                        • Aug 2007
                        • 880
                        • Ontario, Canada
                        is yours away now Alex or are you waitin for one more nice day? Tomorrow could be it!
                        Paul
                        1983 XJ1100 Maxim
                        1980 XS1100 Special
                        • Axel
                          • May 2007
                          • 869
                          • Renfrew,Ontario
                          one more at least
                          I was out on Tuesday (short run) .Wednesday I installed my new SS lines . I still have to bleed but tomorrow could be the day !!! I'm hoping for a good run to test my brakes on one of these balmy days coming up .
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
                          • olebiker
                            • Aug 2007
                            • 692
                            • Kingston ON
                            I got two away and waiting for a spot for Kathi's. Think I will keep the KLR out till I get a couple of snow rides on it.
                            http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                              • 2117
                              I have a storage unit(10 x 10) that the 2 bikes fit into,however last year problems and work related issues kind of made me neglect going to my unit every other weekend.This year coming up since both bikes are in my Mothers garage,she said i could keep them there for the winter.Both bikes are hooked up to the trickle charger and tires are off the ground.I start the bikes every 2 weeks or sooner if i get the chance.If i get a nice day i might take it for a ride on the street,so i don't drain the gas,only keep stabil and Berrymans chem tool in the tank.
