ok so i disconnected the field coil and connected it to a battery for a very short period of time, like less than a second at a time, and it would attract a paper clip...I believe that its a bad connection somewhere. im going to try to find connector for the plugs exactly and hopefully that will fix it.
carb help needed...these things are picky
So i got it to charge. all it was was the plug that goes from the stator to the wiring harness. i had a stator laying around with a good plug so i cut it off and spliced it on to mine and it charges at like 14.4V now. So it will get higher in rpm's but it still sputters at about 6K rpm, but the plugs are fouled and i believe the jets i have in the carbs are too big...147.5..others with the pod filters and 4 into 2 exhaust have 145 main jets. my 145's mysteriously disappeared.....so ill tune it this summer.It seemed like a good idea at the time....
1991 Honda Nighthawk CB750...R.I.P.
Awesome...
1978 Yamaha XS1100e Purple People EaterComment
Last Yamaha I owned had same electrical problem: connector from stator to system had corroded/burnt. PO bailed on bike cause "mechanic" replaced battery twice as the "fix". Third time mechanic said it needed new stator and rectifier. PO gave up and parked the bike until I bought it. I stuck my face in the system and found just what you did.
Congrats on a successful "hunt".
Bike had been run in rain repeatedly and all those important connections were in same sorry state. I took the time to examine/clean all those that I could get at. Bike never stranded me due to an electrical problem after that.Comment
yyeahhhh i tell u what it was a hunt. so now i have to tune it, carb wise. im sure ill get there. i think im going to go through and get a bunch of electrical connectors and refurb all the connectors.It seemed like a good idea at the time....
Awesome...
