The backfiring along with no high end power makes me wonder about your ignition timing. Have you put a light on it?
If you are in time, and have black plugs with no power, I would guess that you may, in fact, be too rich. This would also cause exhaust backfire.
It is difficult to ascertain a rich or lean sound with out a "calibrated ear". The best I can say is that a lean running engine sounds and feels hot, crackly, and flat. A rich engine sounds gurgly, soggy and sluggish.
Does the engine just quit pulling, or does it start missing when you are up in the revs?
Personally, I am starting to think you might want to look into other places than the carbs. When I wrenched on old cars, carbs were always the last place to look. Everything else on the engine needs to be sound before the carb can do its job, even if it is perfect. The fact that carbs are 1 part science, 1 part luck, and 8 parts voodoo doesn't help the average joe much at all.
Too bad you're not closer, you could bring it to "Fat Ive's Garage". anything is possible to fix, with enough beer.
