Hi beechfront.
I had recollection of the same problem. I have had K&N indy's since I bought the bike many years ago. One spring after cleaning I accidently put too much of the K&N filter oil on the filters. The bike would NOT go over 4500 RPM, it bogged right down. I re-cleaned the filters and put them back on dry just to test, and it wound up fine. So I have been less liberal in the filter oil application.
Did you answer the question about the spark plugs? What do they look like? Clean them well or start with new ones, run for a minute at 6000 RPM, do the throttle chop and look at the plugs.
And I would check anything else that might limit your RPM. Ignition stuff can be finicky, timing ( I had that problem), vacuum advance hose leaking (I had that too). Is your battery up to snuff?
I think the pilot is mostly for idle to ~2000 RPM.
About that gas on the floor, one spring I started my bike - after its long hibernation - and then went in to dress for a trip. When I went back out there was gas running down the driveway. One of the float needles had stuck open. Either varnish or a small piece of dirt got in there. Fortunately I was parked on a hill and did not get any into the crank case. Watch for that also.
And thinking of your safety, I think on your private jetway, running a test at 6,000 RPM + in second gear will probably tell you what you need to know. Until you get it running right, you can calculate the MPH you could have hit at 6,000 RPM in 5th.
Let us know!
Let us know!
