Idle problems and hard to start after hot
This topic is closed.
  • JOEY
    • Jun 2008
    • 73
    • Hastings,Fl
    Ok I rode my 82 xj for a 50 mile trip and I found out it misses on exceleration up to 3000 rpms after that it will run like a bat out of hell. Than when I go to stop sometimes it will idle fine with a little miss and sometimes it will just cut off. Than if I try to start it up when it is hot I have to turn the choke all the way out to get it started again than its fine. HELP PLEASE.
    It is better to stay silent and be thought a fool, than to open one’s mouth and remove all doubt.
  • GARTHXS
    • 1631
    • Seattle
    plug color
    Check your plugs , see if your runnin lean, and I reccomend a proper carb sync
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • JOEY
      • Jun 2008
      • 73
      • Hastings,Fl
      I checked plug 1 and 2 and it is a whitish color.
      • Tusler
        • Jul 2008
        • 79
        • Hemet, CA
        Hi Joey,
        I think we have similar problems. My xs1100 when I start it cold sounds like it is running on 3 cyl until I pull the choke full on. If I start riding it right away when I get it above 2000 rpm it runs great, below that it misses and pops a little. The difference is when mine gets warm it will ide ok if I have set for 11 to 1200 rpm idle. If I lower it to 1050 it will die everytime after a few minutes. I think it is a low speed jet problem because it runs good when on the main jet. I have decided to live with mine until it gets unbearable. I have no idea if this will work,help or hurt. But back when I worked on old cars I use to remove the air cleaner and put some rpm on the motor then close the choke butter fly while opening the throttle fly all the way momentarily to create a massive vacuum and suck everything out of the passages in the carb. Couldn't hold it at all or the engine would die but it use to clean or open a stuck passage sometimes. I guess in our bikes it would be like bring up the rpm and cover one carb to create a vacuum and see if it will open up a plugged or gummed passage inside.
        1980 Xs1100 MNS Sold for $1800
        2004 Roadstar XV1700
        45 to 50 MPG
        Ask Jesus for Forgiveness before it is too late!
        • firstxs1100
          • Sep 2008
          • 46
          • gate city va
          hey tusler
          hey tusler just read your post and wanted to comment not on the post but on your words at the bottom
          just want to say praise god brother and keep on the firing line for jesus the king.
          Romans 5:8
          But God commendeth his love toward us, in that, while we were yet sinners, Christ died for us.
          JESUS LOVES ALL OF YOU FOLKS
          • GARTHXS
            • 1631
            • Seattle
            topic
            Look I am a christian as well but can we just talk about bikes
            91 kwaka kz1000p
            Stock
            • JOEY
              • Jun 2008
              • 73
              • Hastings,Fl
              Could it be because I am running it without an air filter or does it need a carb cleaning.
              • JOEY
                • Jun 2008
                • 73
                • Hastings,Fl
                You mean out of 46 people that has looked at this thread and all I get is a praise the lord and an amen not that it was bad advice mind you.
                  Whitish plugs mean very lean condition. Either the pilot (idle) circuits are plugged or idle mixture screws are in too far. Try turning them out a bit and see if it improves. If no improvement, time to do a carb cleaning. Put your air filter back in first before adjusting. HTH
                  • JOEY
                    • Jun 2008
                    • 73
                    • Hastings,Fl
                    Where are the idle mixture screws located at?
                    • blue giant
                      • Aug 2007
                      • 880
                      • Ontario, Canada
                      Joey,
                      If you don't have a manual, check out the carb links in the maintenance threads on the main forum page. A lot of good info there!
                      Good luck!
                      Paul
                      Paul
                      1983 XJ1100 Maxim
                      1979 XS1100 Standard
                      1980 XS1100 Special
                      • egsols
                        • Jan 2006
                        • 1090
                        • Barrie, Ontario, Canada
                        Running without an air filter is probably not a good idea. Lots of tiny little pieces of junk can get sucked in an cause many a problem, if it hasn't already.
                        Yes, white plugs are an indication of running lean, something you don't want to do for too long either.
                        Like Blue Giant said, check out the tech tips and if you have access to manual that is a definite plus.
                        First of all try running it with the stock air cleaner in place and see how it runs. You may need to pull the carbs for a good cleaning and then set them up with a sync.
                        Tusler,
                        If it idles okay at 1100-1200 but not lower, you probably need a sync.
                        Ernie
                        • firstxs1100
                          • Sep 2008
                          • 46
                          • gate city va
                          garthxs
                          garthxs if jesus was on here himself and he asked about a problem he was having with people not telling others about his great love would you tell him to go somewhere else and talk about his problems because this is a place to talk about bikes.
                          i understand that this is a site to talk about bikes but why not let your light shine and tell people about jesus as well. maybe even thank him for keeping you safe on each and every ride because alot of people are leaving this world on a bike.
                          why not do what the bible says in psalms 96 and 8 which reads
                          Give unto the LORD the glory due unto his name
                          because he keeps us each and every day.
                          if it makes you happy i will comment on the bike
                          first i would say it would be a good time to clean those carbs. these things are fidgity. if every pathway is not cleaned out like it were new then it won't run right.
                          next for starting. if you have the type of carbs. that have the pilot jet plugged then i would check your emulsion tubes below the main jet to see if the tiny passage just below the main jet hole is clogged this assists your idle circuit in getting an ample supply of gas to idle after 3 or 4 grand this passage stopsworking and the main jet takes over from here. after you come back to idle there may be enough gas to get through this small passage and then there may not be. all i can say about these bikes is they are fidgity little bikes. if everything aint right then it wont run right. espicially these carbs. if you have a bike with one carb and it is off a bit you can deal with it pretty easily but if you have 4 carbs. and one gets off then the one that gets messed up will fight against the other 3 and mess the whole thing up. i hope this makes sense.
                          Romans 5:8
                          • JOEY
                            • Jun 2008
                            • 73
                            • Hastings,Fl
                            It makes complete sense looks like im taking the carbs off tommorrow and cleaning them Thanks for all the replys.
                              Just a reminder
                              Don't soak (immerse) the carb bodies in solvent. This will destroy the butterfly shaft seals. Also, they don't need to be seperated from their bank to be properly cleaned. Good luck!
