Question on plug leads
  • XSrunner
    • Feb 2008
    • 97
    • Batemans Bay AUSTRALIA
    Hi all i was reading the tips on the new mikes xs coils and I was wondering why do we need to run those ngk plug ends?? can't we have normal car plugs on them??
    JOHN'O
    Xs1100E 1978
    American Import Cruiser
    • 7641
    With the new coils, you can. Just don't get too close to ANY AM radio, and MOST FM radios. If you are running resistor plugs, AKA platinum or iridium, it won't matter quite as much.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      With the new coils, you can...
      Why only new coils? The PO on my bike replaced the plug boots and wires as shown in the "New Wires in Old Coils" thread. Will this cause a issue?
      Thanks,
      Ozz
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
        Hey John'O,
        The NGK caps are much more durable, they use the smaller threaded plug end connector vs. the larger auto rounded cap..I know there are tecnical terms for them, but I can't remember them right now!
        The hard plastic NGK caps are easier to remove from the plugs vs. the softer auto style.
        Ozz, the old coils put out about 15Kvolts, the new ones are rated at ~35Kvolts, and so with stronger coils, stonger pulses, stronger radio frequency interference when not using resistor caps or plugs!
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          NGK also makes caps that fit standard automotive style plug ends. The guy at the MC shop here in town looked at me like I was painted blue when I asked for one that fit the threaded stud. He had never seen one.
          FWIW, the silicone boots on automotive style wires will tear and split when exposed to kids messing with your bike, getting on and off and the such where they get moved around a lot. They also have a tendency to stick to the plug, making removal a real pain, after a couple thousand miles, they pretty much rip apart on removal.
          Ich habe dich nicht gefragt.
          • MrOzz
            • Aug 2008
            • 782
            • Massachusetts
            Sounds like a good excuse to replace my coils then. Like I need one, lol.
            Any recomendations? Reading the threads it seems like the ones from Mikes XS are good choice. I have noticed some members using the Accel coils. Any real difference other than name and price?
            Thanks,
            Ozz
            1980 XS 1100SG
            Pod Filters
            DynoJet Kit
            T.C.'s Fuse Block
            V-Max Auto CCT
              • 8672
              coils
              I have the Accel Supercoils on my Special, and the spark seems to be a bit hotter than the Mike's coils. I have the Mike's on my Standard and they are plenty hot. The Accel's are almost $200 a pair vs. the Mike's at about $75 a pair. The Accels use the automotive plug tip connectors at both ends.
              • MrOzz
                • Aug 2008
                • 782
                • Massachusetts
                Is there a voltage differance on the accels comparied to the ones on MikesXS? If so what is it?
                Thanks,
                Ozz
                1980 XS 1100SG
                Pod Filters
                DynoJet Kit
                T.C.'s Fuse Block
                V-Max Auto CCT
                  • 8672
                  MrOzz, the Accel coils P/N 140403 are 3 ohm and 35K+ volts output. Don't know the specs on the Mike's.
