rim and tire set
  • selfmade
    • 54
    rim and tire set
    I know a 140 tire will fit on the back and the concensus is that is the largest that can be mounted. Now my question is; is that the largest tire for the stock rim or does the drive shaft tube prevent bigger tires? I am wondering.
    • 3193
    I have a 140/90-16 on my bike. You can pretty much just get a matchbook cover between the driveshaft and the tire.
    • selfmade
      • 54
      i see that avon roadriders come in a 150/80-16 for the rear. I understand that it will not clear the driveshaft tube as it is, but i could notch the tube to fit. Also in conjunction with notching the tube i am doing away with the whole swingarm anyways. For what it is worth the rear rim is 3.50 in. wide
      • selfmade
        • 54
        rasputin,
        is that the driveshaft or the driveshaft tube?
          Hey there Self,
          The 17" rear rim is 2.5" wide, the 16" is 3.0" wide, so depends on which rim you use, but yes, the driveshaft housing is the main limiting factor, but I think I remember seeing on the tire sites about needing a wider rim for some of the wider tire profiles vs. what we currently have!
          PS, didn't see your recent post until I submitted this one! The driveshaft is not too far from the edge of the housing, so don't think you'll get too much more clearance with a hard tail design, but you'll probably get 1/4" or more!
          • selfmade
            • 54
            do you think i will be able to get teh 150 on there?
              You may get the 150 in there, as 10mm is about 5/16", and divided by 2 you would need an extra 5/32". The problem is you WILL need to notch the tube for the driveline, and loose the strength of the tube!! The swing arm tube is the size to clear the END of the drive shaft. If you just heat up and bend the tube in a little, the driveline will NO LONGER clear the "bend"!!
              I would think welding extra supports on top and bottom should keep it from flexing, but you would want to TEST it first.
              • selfmade
                • 54
                I was already planning on the notch. I did the same thing to my vtx1800 to fit a 280 and there were no problems.
                • mitch
                  • Oct 2002
                  • 934
                  What About
                  Talk to chop and convert the sucker to chain drive a few have here
                  Doug Mitchell
                  82 XJ1100 sold
                  2007 Stratoliner 1900 sold
