oil drain washer ref
  • greg maz
    • Feb 2008
    • 219
    • Arlington Heights, CA
    anybody knows on how to get a replacement washer for the oil drain?
    any make do look alike ducted it did it?
    otherwise I'll look to buy online but I'd hate to be stranded that long
    82 XJ1100 Klonk= SOLD
    No longer active member.
    Hi Greg,
    nearest NAPA store or equivalent? Take the drain bolt with you to make sure you get the correct size. Any copper or aluminum or red fiber washer that fits will work. Or go upmarket with a bonded sealing washer.
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      A spark plug washer works.
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
        • 2117
        Even with a brand new bolt and washer mine leaked so i put some Teflon tape on the threads and that stopped the leak.
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          Yeah, good idea, oldyam80sg. I always use a new crush washer, teflon tape on the bolt threads, and spread a little RTV on the washer. Never had a leak yet.
          23mm float height
          120 main jets
          42.5 pilot jets
          spade fusebox
