electical woes
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    here are some pics
    here are the pics of the old stuff before I took it out
    these are the before , Ill post some afters later
    Last edited by Ken Talbot; 11-03-2008, 07:58 PM. Reason: inaserted space between text and photos, and space between individual photos
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • big_dave
      • Jul 2007
      • 27
      • Algoma, WI
      wiring harness
      I have a 1978 wiring harness, I bet it would be cheaper than anywhere on the planet, $10 + shipping.
      Dave
      • LegendJet
        • 32
        • Memphis, Tenn.
        mine also has the 3 wires coming out of the right hand switch but has 5 pins on the connector to the wiring harness. I believe some of the XS11's came with an extra switch found on the right hand control that can turn the lights on or off. Ive see pics on some. i believe thats what those 2 pins are. i believe they go to the reserve lighting unit. I have a right hand control on the way with the 5 wires. when i get it and plug it in i'll tell u if it works.
        It seemed like a good idea at the time....
        1991 Honda Nighthawk CB750...R.I.P.
        Awesome...
        1978 Yamaha XS1100e Purple People Eater
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          #34
          me too
          Yeah mine is like that but it has the light switch , still trying to iron out misc. Wiring no signals yet and hand brake switch not working
          91 kwaka kz1000p
          Stock
          • GARTHXS
            • Nov 2007
            • 1631
            • Seattle
            #35
            almost done
            So I am almost finished headlight works and everything else except no oil light, and my right front signal is so corroded I can't get the bulb out , I am going up to the Wiz's in the morning he says he has a couple of extra signals he can part with and I should have it fixed , oh yeah when I am trying to park and turn the bars hard left the motor cuts out. I re routed the wires but it still happens , I guess I will pull the connector and see what's loose
            91 kwaka kz1000p
            Stock
            • LegendJet
              • 32
              • Memphis, Tenn.
              #36
              it could be the throttle cable. When i turned mine hard right it would idle up, and when i turn it hard left it idles down. just adjust idle up alittle
              Awesome...
              • GARTHXS
                • Nov 2007
                • 1631
                • Seattle
                #37
                not so much
                I have played that game before, th left turns go so much faster
                91 kwaka kz1000p
                Stock
