Master Cylinder Reservoirs
  • magnum440
    • 64
    • Farmville, NC
    Hello, I need to find new reservoirs for my XS1100SG, front and rear. If there are non available, can I use different m/c? I don't want to order the rebuild kits until I can find reservoirs. They are both very brittle. Thanks, Stacy
    Stacy Clontz Farmville, NC
    1980 XS1100SG
    1971 Maico 400 Square Barrell
    1973 Honda CR250M
  • latexeses
    • Jun 2008
    • 1491
    • California
    Don't know if this will be much help but I found this today while looking for rebuild kits for the masters.
    part # 08-0204
    Might be a start.
    Maybe someone here has had some input on these.
    I'll be watching one this myself as the PO of my F figured that it needed plenty of sunshine and weather. My masters are tired as well.
    Everything on hold...
    • magnum440
      • 64
      • Farmville, NC
      I looked around on the net last night and I believe I can find something for the front. My problem is the rear. The ones on eBay don't look any better than the one I have. I did a little searching on this site and saw that someone had replacement reservoirs listed sometime back.
      1980 XS1100SG
      1973 Honda CR250M
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        The resevoir looks good on this one.
        http://cgi.ebay.com/ebaymotors/1980-...mZ250267952213
        Tim
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
        • magnum440
          • 64
          • Farmville, NC
          Thanks XSPastor, didn't see that one. I did my sexrch with no space between XS and 1100. Live and learn. Thanks again, Stacy
          1980 XS1100SG
          1973 Honda CR250M
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            Try searching on the following.
            XS11*
            XS 11*
            XS eleven
            I find these 3 searches gets pretty much all of them.
            Geezer
            • XSPastor
              • Oct 2007
              • 602
              • Gaithersburg, MD
              Here's a brand new one:
              http://cgi.ebay.com/ebaymotors/YAMAH...mZ300265272481
              23mm float height
              120 main jets
              42.5 pilot jets
              spade fusebox
              • magnum440
                • 64
                • Farmville, NC
                I got a rear master cylinder off of an '81. It doesn't have the same style reservoir as my '80 one does. Will this still work? Looks like bolting up is not a problem.
                1980 XS1100SG
                1973 Honda CR250M
                • DeanR
                  • Jan 2005
                  • 1499
                  • Finger Lakes NY
                  Rear master cylinders on my 80 & 81 are identical.
                  80 SG
                  81 SH in parts
                  99 ST1100
                  91 ST1100
                  • magnum440
                    • 64
                    • Farmville, NC
                    Maybe the one I got is not for an '81. It doesn't have the plastic reservoir, it only has a cap.
                    1980 XS1100SG
                    1973 Honda CR250M
                    • Montreux_Blue
                      XS-XJ Guru (Deceased)
                      • 1143
                      Originally posted by XSPastor
                      They just gave that one away for that price!
                      Famous Myspace quote:
                      • XSPastor
                        • Oct 2007
                        • 602
                        • Gaithersburg, MD
                        Yeah - the guy didn't spell cylinder correctly or he might've had more bidders... He sold the whole thing for what you'd have to pay for just a rebuild kit.
                        23mm float height
                        120 main jets
                        42.5 pilot jets
                        spade fusebox
                        • MrOzz
                          • Aug 2008
                          • 782
                          • Massachusetts
                          Magnum,
                          From my understanding any front brake master cylinder will work as long its for a dual front caliper, has proper bolt hole, I think 10mm, and fits 7/8th bars. Ive been looking myself and what I have found is the ones with the sight glass and not the all clear reservoir like on the XS. If you find front and rear let me know.
                          Ozz
                          1980 XS 1100SG
                          Dyna 3 Ohm Hi Output Coils
                          Pod Filters
                          DynoJet Kit
                          T.C.'s Fuse Block
                          V-Max Auto CCT
                          • CatatonicBug
                            • 6117
                            • Clinton, UT
                            Mine has full black (painted) aluminum with a tiny window for the front, and full black with no window for the rear. Isn't that how all the XS's are made? Or is that only because mine is a Midnight?
                            • Geezer
                              • May 2003
                              • 2985
                              Magnum,
                              You're close. It should have 5/8" or 16mm bore for dual disk brakes. It's 10 or 12mm is for single disk. Most bikes also have 7/8" bars but Harleys and some cruisers have 1" diameter bars so most dual disk Japanese mastercylinders will work. If you get one from some other bike, you can also loose the left hand thread mirror mount.
                              I have a very nice looking Kaw Ninja mastercylinder I was going to use but it doesn 't have a mirror mounting hole. I'll probably get one from Parts'N more when they come back in stock. Mike's XS is out of them too.
                              Geezer
