Hello, I need to find new reservoirs for my XS1100SG, front and rear. If there are non available, can I use different m/c? I don't want to order the rebuild kits until I can find reservoirs. They are both very brittle. Thanks, Stacy
Master Cylinder Reservoirs
Don't know if this will be much help but I found this today while looking for rebuild kits for the masters.
part # 08-0204
Might be a start.
Maybe someone here has had some input on these.
I'll be watching one this myself as the PO of my F figured that it needed plenty of sunshine and weather. My masters are tired as well.RIP Whiskers (Shop Boss) 25+yrs
Everything on hold... -
I looked around on the net last night and I believe I can find something for the front. My problem is the rear. The ones on eBay don't look any better than the one I have. I did a little searching on this site and saw that someone had replacement reservoirs listed sometime back.Stacy Clontz Farmville, NC
1980 XS1100SG
1971 Maico 400 Square Barrell
1973 Honda CR250MComment
Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fixComment
The old gray biker ain't what he used to be.Comment
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
I got a rear master cylinder off of an '81. It doesn't have the same style reservoir as my '80 one does. Will this still work? Looks like bolting up is not a problem.Stacy Clontz Farmville, NC
1980 XS1100SG
They just gave that one away for that price!Here's a brand new one:
http://cgi.ebay.com/ebaymotors/YAMAH...mZ300265272481
1980 XS11 Special - chopped, dropped and OCTY is still installed
- NOW IT'S FOR SALE! $1,800 OBO
Famous Myspace quote:
It's funny because I am from TEXAS!Comment
Yeah - the guy didn't spell cylinder correctly or he might've had more bidders... He sold the whole thing for what you'd have to pay for just a rebuild kit.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
Magnum,
From my understanding any front brake master cylinder will work as long its for a dual front caliper, has proper bolt hole, I think 10mm, and fits 7/8th bars. Ive been looking myself and what I have found is the ones with the sight glass and not the all clear reservoir like on the XS. If you find front and rear let me know.
Ozz
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCTComment
Mine has full black (painted) aluminum with a tiny window for the front, and full black with no window for the rear. Isn't that how all the XS's are made? Or is that only because mine is a Midnight?1980 XS850SG - Sold
-H. FordComment
You're close. It should have 5/8" or 16mm bore for dual disk brakes. It's 10 or 12mm is for single disk. Most bikes also have 7/8" bars but Harleys and some cruisers have 1" diameter bars so most dual disk Japanese mastercylinders will work. If you get one from some other bike, you can also loose the left hand thread mirror mount.
I have a very nice looking Kaw Ninja mastercylinder I was going to use but it doesn 't have a mirror mounting hole. I'll probably get one from Parts'N more when they come back in stock. Mike's XS is out of them too.
GeezerHi my name is Tony and I'm a bikeoholic.
