Help Unlinking XJ Brakes
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    I have been involved in brake upgrades on my XJ . I have a new front master from mikesxs.com and want to change the linked brake setup to the conventional one . I have had trouble getting good SS lines but am still trying . The front discs are fairly easy to convert with two equal length hoses . The rear is another matter . Please share your experience with this conversion . In other words ...HELP
    P.S. I wish I had never started this because it worked well the old way .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
  • mitch
    • Oct 2002
    • 934
    Bud
    I left the old system in place on mine just plugged off the line going from the rear MC . Worked great a lot more front and rear brake
    Doug
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
    • mitch
      • Oct 2002
      • 934
      Axle
      I took the fitting off the line comin out of the equlizer valve and cut the end off it soldered it shut and put it back in to block the system . Then only the rear brake was working on the rear MC. That MC is made to run 2 Calipers so be eazy on the rear brake after you do this . It will lock up with very little pressure and thats what i wanted .
      Doug
      Doug Mitchell
      82 XJ1100 sold
      • blue giant
        • Aug 2007
        • 880
        • Ontario, Canada
        Alex,
        Have you considered swapping out the rear master for an XS master? I have a spare here if you want it.
        It will likely need a kit but you are welcome to it.
        Paul
        Paul
        1983 XJ1100 Maxim
        1979 XS1100 Standard
        1980 XS1100 Special
          The XS m/c won't mount up to the spots on the frame that the XJ does. Actually.. it will, but the angle would be all wrong. You'd have to cut the mounting points off the frame and re-weld them in the right position for it to work.
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            rear ok ?
            I've had a weekend of using one front caliper and the rear caliper alone . Actually its almost the same as before . I'm getting used to it . I never had much rear brake with the linked system anyway . I may leave it as is to avoid having to get used to a sensitive rear brake and possible accident . When both front calipers are working together ,It may take some getting used to so one thing at a time .
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • Fredjohny
              • 74
              • Gibsons, BC Canada
              I unlinked mine with xs components they all bolted on..... mc as well because of volume differences
              82 XJ1100 Maxim
              80 XS1100 engine and parts doner
              Awsome machine.....love going on rides.....
              black on black
